Code comArduino: 1.8.5 (Windows 7), Board "Arduino Uno" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardwarepilation error.
Hello everyone. I want you to help me with a compilation problem that I can't solve. I'm using Arduino IDE 1.8.5. I am attaching the code and the error. I hope to find an answer. Thank you.
#include <EEPROM.h>
#include <Wire.h>
//use #include <LiquidCrystal.h> if you don't have I2C LCD
#include <MenuSystem.h>
#include "defs.h"
#include "VdiLcd.h"
#include "params.h"
#include "menu.h"
#include "encoder.h"
//use "LiquidCrystal" if you don't have I2C
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
CVDILcd vdi(&lcd);
CParameters params;
extern MenuSystem ms;
//signal processing
bool generateReading(int* pPhase, int* pStrength, unsigned char* signalValues, bool* pbadReading)
    #define SAMPLE_BUFFER_SIZE 350
    unsigned char strenth[SAMPLE_BUFFER_SIZE] = {0,};
    unsigned char angle[SAMPLE_BUFFER_SIZE] = {0,};
    int index = 0;
    bool enoughSamples = false;
    unsigned long startTime = millis();
    bool needToClearLastResult = true;
    bool retValue = true;
    while(1)
      //digitalWrite(8, LOW); //debug
      //delayMicroseconds(100);//debug
      //digitalWrite(8, HIGH); //debug
      //check the encoder and break out of the processing on user button press
      if(checkEncoder())
        params.m_showVDI = false;
        retValue = false;
      //sample signals
      float X = 0.0F;
      float R = 0.0F;
      const int SAMPLING_LOOP = params.m_readingSamples;
      for(int n(0);n<SAMPLING_LOOP;n++)
        X += analogRead(XPin);
        R += analogRead(RPin);
      X /= SAMPLING_LOOP;
      R /= SAMPLING_LOOP;
      //Serial.print("------------------------------------------\r\n");
      //Serial.print(X - params.m_XBias);
      //Serial.print(",");
      //Serial.print(R - params.m_RBias);
      //Serial.print("\r\n");
      //delay(5);
      //continue;
      //if opamp is saturated; break and report it
      if(X >= params.m_maxSignal || R >= params.m_maxSignal)
        *pbadReading = true;
      //bring to "virtual ADC zero"
      X = X - params.m_XBias;
      R = R - params.m_RBias;
      //screen out samples using signal R polarity as set in params
      // 0 - use any polarity
      //-1 - use only negative R
      // 1 - use only positive R
      if( (params.m_sigPolarity<0 && R>0) || (params.m_sigPolarity>0 && R<0) )
        X = 0.0F;
        R = 0.0F;
      //phase in degrees
      int phase = ( (X == 0.0F && R == 0.0F) ? 0 : atan2(X, R) * 57.295F );
      if(phase < -90)
       phase = -90;
      else if(phase > 90)
        phase = 90;
      angle[index]   = phase + 90;
      strenth[index] = int(sqrt(X*X+R*R));
      index++;
      //ring buffer; wrap around
      if(index >= SAMPLE_BUFFER_SIZE)
        enoughSamples = true;
        index = 0;
      if(!enoughSamples)
        continue;
      //find peak signal
      unsigned char maxVal = 0;
      int maxIndex = -1;
      for(int n(0); n<SAMPLE_BUFFER_SIZE; n++)
        if(strenth[n] > maxVal)
          maxVal = strenth[n];
          maxIndex = n;
      //is the peak strong enough
      if(maxVal < params.m_minSignal)
        //no strong signal is present; its a good time to clear LCD if needed
        if(needToClearLastResult && (millis() - startTime) > 5000)
          unsigned char empty[40]={0};
          vdi.updateVDI(params.m_vdiStyle, 0, 0, empty, false);
          needToClearLastResult = false;
        continue;
      //where in the buffer is the peak
      int dist = index - maxIndex;
      if(dist < 0)
        dist = SAMPLE_BUFFER_SIZE + dist;
      //check if the peak is in the middle of the buffer
      if(dist != SAMPLE_BUFFER_SIZE/2)
        continue;
      //we have strong enough peak in the middle of sampling buffer
      //calculate the result and break the loop
      float angleAvg = 0.0F;
      float strengthAvg = 0.0F;
      int avgSamples = 0;
      const int reach = 1;
      int n = maxIndex - reach;
      while(avgSamples < (reach*2 + 1))
        if(n<0)
          n += SAMPLE_BUFFER_SIZE;
        else if(n>=SAMPLE_BUFFER_SIZE)
          n %= SAMPLE_BUFFER_SIZE;
        angleAvg    += (int(angle[n]) - 90);
        strengthAvg += strenth[n];
        avgSamples++;
        n++;
      *pPhase = angleAvg/avgSamples;
      *pStrength = strengthAvg/avgSamples;
      //sound handling
      if(params.m_soundOn)
        tone(SND_PIN, *pPhase <= 0 ? SND_LOW_TONE : SND_HIGH_TONE, SND_LENGTH);
      //prepare data for the 40x8 graph
      int i = 0;
      int k = index;
      const int inc = SAMPLE_BUFFER_SIZE/40;
      while(i<40)
        if(k>=SAMPLE_BUFFER_SIZE)
          k -= SAMPLE_BUFFER_SIZE;
        signalValues[i] = float(strenth[k])/float(maxVal) * 8;
        k+=inc;
        i++;
      //measurement completed; break the loop
  return retValue;
// Standard arduino functions
  //restore from EEPROM
  params.loadParams();
  //LCD init
  lcd.begin(16,2);
  lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
  lcd.setBacklight(params.m_LcdBacklight ? LED_ON : LED_OFF);
  //create menu
  createVDIMenu();
  //Encoder setup
  pinMode(PIN_ENC1, INPUT);
  pinMode(PIN_ENC2, INPUT);
  pinMode(PIN_EBTN, INPUT);
  pinMode(PIN_LED1, OUTPUT);
  digitalWrite(PIN_ENC1, HIGH);
  digitalWrite(PIN_ENC2, HIGH);
  digitalWrite(PIN_EBTN, HIGH);
  attachInterrupt(0, intrEncChange1, CHANGE);
  attachInterrupt(1, intrEncChange2, CHANGE);
  checkEncoder();
  //initialize LCD GUI
  lcd.clear();
  lcd.home();
  lcd.setCursor(0,0);
  lcd.print("VDI v0.3");
  unsigned char signalValues[40]={0};
  params.m_showVDI = true;
  vdi.reset();
  vdi.updateVDI(params.m_vdiStyle, 0, 0, signalValues, false);
    tone(SND_PIN, 700, 200);
    delay(200);
  //Serial.begin(115200);
  if(params.m_showVDI)
    int phase(0.0F);
    int strength(0);
    bool badReading(false);
    if(generateReading(&phase, &strength, signalValues, &badReading))
      vdi.updateVDI(params.m_vdiStyle, phase, strength, signalValues, badReading);
    encoderHandler();
have a read of how-to-get-the-best-out-of-this-forum
in particular
  1. what arduino are you using?
  2. in the Arduino IDE select File>Preferences and enable "Verbose output during Compiling and upload" then compile - upload the error message text
Remove the very first line. It is the remnants of a comment. Not needed.
Hi Horace. I use arduino uno and I copied the text with the error
Arduino: 1.8.3 (Windows 7), Placă"Arduino Uno"
C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\hardware -hardware C:\Users\ovidiu\AppData\Local\Arduino15\packages -hardware C:\Users\ovidiu\Documents\Arduino\hardware -tools C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\tools-builder -tools C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\hardware\tools\avr -tools C:\Users\ovidiu\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\libraries -libraries C:\Users\ovidiu\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671 -warnings=all -build-cache C:\Users\ovidiu\AppData\Local\Temp\arduino_cache_112707 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\ovidiu\Documents\Arduino\tgsl_cu_VDI\tgsl_cu_VDI.ino
C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\arduino-builder -compile -logger=machine -hardware C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\hardware -hardware C:\Users\ovidiu\AppData\Local\Arduino15\packages -hardware C:\Users\ovidiu\Documents\Arduino\hardware -tools C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\tools-builder -tools C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\hardware\tools\avr -tools C:\Users\ovidiu\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\libraries -libraries C:\Users\ovidiu\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671 -warnings=all -build-cache C:\Users\ovidiu\AppData\Local\Temp\arduino_cache_112707 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\ovidiu\Documents\Arduino\tgsl_cu_VDI\tgsl_cu_VDI.ino
Using board 'uno' from platform in folder: C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\VdiLcd.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\encoder.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\params.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\Wire.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\utility\twi.c" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master\LiquidCrystal_I2C.cpp" -o "nul"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem\MenuSystem.cpp" -o "nul"
Generating function prototypes...
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\ovidiu\AppData\Local\Temp\Rar$EXa2392.6838\Arduino-1.8.3-IDE-Windows-master\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilez schi?a...
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\VdiLcd.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\VdiLcd.cpp.o"
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\VdiLcd.cpp: In member function 'void CVDILcd::paintBigNumVDI(int, int, unsigned char*, bool)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\VdiLcd.cpp:35:84: warning: unused parameter 'signalValues' [-Wunused-parameter]
 void CVDILcd::paintBigNumVDI(int phase, int strength, unsigned char signalValues[40], bool badReading)
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\encoder.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\encoder.cpp.o"
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp.o"
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:15:20: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 Menu mm("VDI menu:");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:19:30: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meShowVDI("Show VDI");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:20:35: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetVDIStyle("VDI style");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:21:38: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetMinSignal("Min sig val");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:22:38: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meCalibZero("Calib ADC zero");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:23:36: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meCalibMax("Calib ADC max");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:24:40: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meShowSignal("Show raw signal");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:25:44: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meShowSignalRange("Show sig range");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:26:36: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetBacklight("Backlight");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:27:40: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meLoadDefaults("Load defaults");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:28:28: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetSound("Sound");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:29:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetPolarity("Signal polarity");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:30:39: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 MenuItem meSetOversampling("Averaging");
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onShowVDISelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:86:34: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onShowVDISelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetVDIStyleSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:95:38: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetVDIStyleSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetMinSignalSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:100:39: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetMinSignalSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onCalibZeroSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:105:36: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onCalibZeroSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onCalibMaxSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:169:35: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onCalibMaxSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onShowSignalSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:210:37: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onShowSignalSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onShowSignalRangeSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:276:42: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onShowSignalRangeSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetBacklightSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:323:39: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetBacklightSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onLoadDefaultsSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:335:39: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onLoadDefaultsSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetSoundSelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:347:35: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetSoundSelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetPolaritySelected(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:352:38: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetPolaritySelected(MenuItem* p_menu_item)
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp: In function 'void onSetOversampling(MenuItem*)':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\menu.cpp:357:34: warning: unused parameter 'p_menu_item' [-Wunused-parameter]
 void onSetOversampling(MenuItem* p_menu_item)
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\params.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\params.cpp.o"
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\params.cpp: In member function 'void CParameters::loadParams()':
C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\params.cpp:50:14: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     if(magic == CURRENT_MAGIC)
"C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\standard" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src" "-IC:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master" "-IC:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem" "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp" -o "C:\Users\ovidiu\AppData\Local\Temp\arduino_build_989671\sketch\tgsl_cu_VDI.ino.cpp.o"
tgsl_cu_VDI:17: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
In file included from C:\Users\ovidiu\Documents\Arduino\tgsl_cu_VDI\tgsl_cu_VDI.ino:8:0:
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:98:2: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t, uint8_t)
  LiquidCrystal_I2C(uint8_t lcd_addr, uint8_t lcd_cols, uint8_t lcd_rows, uint8_t charsize = LCD_5x8DOTS);
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:98:2: note:   candidate expects 4 arguments, 8 provided
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:87:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
 class LiquidCrystal_I2C : public Print {
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:87:7: note:   candidate expects 1 argument, 8 provided
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:87:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
C:\Users\ovidiu\Documents\Arduino\tgsl_cu_VDI\tgsl_cu_VDI.ino: In function 'void setup()':
tgsl_cu_VDI:208: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
   lcd.begin(16,2);
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:106:7: note: candidate: void LiquidCrystal_I2C::begin()
  void begin(); // Int with pin default ARDUINO
C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:106:7: note:   candidate expects 0 arguments, 2 provided
tgsl_cu_VDI:209: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
       setBacklight
tgsl_cu_VDI:209: error: 'POSITIVE' was not declared in this scope
In file included from C:\Users\ovidiu\Documents\Arduino\tgsl_cu_VDI\tgsl_cu_VDI.ino:5:0:
C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src/EEPROM.h: At global scope:
C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM\src/EEPROM.h:145:20: warning: 'EEPROM' defined but not used [-Wunused-variable]
 static EEPROMClass EEPROM;
Utilizând libraria EEPROM la versiunea 2.0 în directorul: C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM
Utilizând libraria Wire la versiunea 1.0 în directorul: C:\Users\ovidiu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
Se folose?te biblioteca LiquidCrystal_I2C-master în directorul: C:\Users\ovidiu\Documents\Arduino\libraries\LiquidCrystal_I2C-master (legacy)
Se folose?te biblioteca MenuSystem în directorul: C:\Users\ovidiu\Documents\Arduino\libraries\MenuSystem (legacy)
exit status 1
check the parameters of the above constructor which is generating an error message
you also have many warnings which would be worth looking at
I tried to change the LiquidCrystal_I2C library and still the same problem...
[image]
if I look at LiquidCrystal_I2C.h the constructor is
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
looks as though you are including the wrong library
where did you find the example for
how is you LCD connected? e.g. I2C or using digital GPIO pins?
the connection to the LCD is I2C, I am also attaching a diagram
[ima
ge]
have a look at the examples LCD Displays (Blue and Yellow) with I2C/TWI Interface
