code compiled with warnings
Hello everyone
I executed a code, it compiled successfully but with warnings.How to avoid these warnings .
warnings are as follows
warning: iteration 15 invokes undefined behavior [-Waggressive-loop-optimizations]
valueall = value;
Users/sravankumarreddy/Documents/Arduino/DG1/DG1.ino:71:9: note: containing loop
  • for (int i=0; i <= 15; i++){*
    actual program is
    #include <SFE_MicroOLED.h>
    #include <Wire.h> // Include Wire if you're using I2C
    #include <SPI.h> // Include SPI if you're using SPI
  • // Include the SFE_MicroOLED library*
    // MicroOLED Definition //
    #define PIN_RESET 9 // Connect RST to pin 9 (req. for SPI and I2C)
    #define PIN_DC 8 // Connect DC to pin 8 (required for SPI)
    #define PIN_CS 10 // Connect CS to pin 10 (required for SPI)
    #define DC_JUMPER 0
    // Also connect pin 13 to SCK and pin 11 to MOSI
    // MicroOLED Object Declaration //
    // Declare a MicroOLED object. The parameters include:
    // 1 - Reset pin: Any digital pin
    // 2 - D/C pin: Any digital pin (SPI mode only)
    // 3 - CS pin: Any digital pin (SPI mode only, 10 recommended)
    MicroOLED oled(PIN_RESET, PIN_DC, PIN_CS);
    //MicroOLED oled(PIN_RESET, DC_JUMPER); // Example I2C declaration
    // I2C is great, but will result in a much slower update rate. The
    // slower framerate may be a worthwhile tradeoff, if you need more
    // pins, though.
    String bluedata;
    String command;
    byte value;
    byte valueall[15];
    char valuechar[15];
  • Serial1.begin(9600);*
  • oled.begin(); // Initialize the OLED*
  • delay(1000);*
  • oled.clear(ALL); // Clear the display's internal memory*
  • oled.display(); // Display what's in the buffer (splashscreen)*
  • // Delay 1000 ms*
  • oled.clear(PAGE);*
  • oled.display();*
  • oled.setFontType(1);*
  • oled.setCursor(0, 0);*
    oled.print("ArduinoGlasses V1.0");
    oled.display();
    delay(2000);
    oled.clear(ALL);
    oled.clear(PAGE);
    oled.display();
    oled.setCursor(0, 10);
    oled.print("Glasses");
    oled.setCursor(10, 30);
    oled.print("Ready");
    oled.display();
    // oled.clear(ALL);
    oled.clear(PAGE);
    if(Serial1.available()){
  • delay(100);*
  • while(Serial1.available()) {*
  • value = (Serial1.read());*
  • if (value == 43 || value == 45){*
_ valueall = value;_
* value = (Serial1.read());*
* int a=0;*
_ String value = ((char*)valueall);_
* //oled.println(test.substring(0, 6));*
for (a=0; a <=15; a++){
* //oled.print(valueall[a]);*
* valuechar[a]=valueall[a];*
* //oled.print("-");*
//oled.clear(ALL);
//oled.clear(PAGE);
oled.setCursor(0, 20);
//command = valuechar[1];command += valuechar[2];command += valuechar[3];command += valuechar[4]; // build number
if (valuechar[0] == 43 && valueall[7] == 49) oled.print("+");
if (valuechar[0] == 45 && valueall[7] == 49) oled.print("-");
if (valuechar[0] == 43 && valueall[7] == 41) oled.print("~");
if (valuechar[0] == 45 && valueall[7] == 41) oled.print("~");
if (valuechar[0] == 43 && valueall[7] == 17) oled.print("+");
if (valuechar[0] == 45 && valueall[7] == 17) oled.print("-");
if (valuechar[0] == 43 && valueall[7] == 9) oled.print("~");
if (valuechar[0] == 45 && valueall[7] == 9) oled.print("~");
oled.print(valuechar[1]);
if (valueall[6] == 49) oled.print(".");
oled.print(valuechar[2]);
if (valueall[6] == 50) oled.print(".");
oled.print(valuechar[3]);
if (valueall[6] == 52) oled.print(".");
oled.print(valuechar[4]);
oled.setCursor(0, 35);
if (valueall[9] == 64 && valueall[10] == 128) oled.print("mV");
if (valueall[9] == 0 && valueall[10] == 128) oled.print("V");
if (valueall[9] == 0 && valueall[10] == 32) oled.print("R");
if (valueall[9] == 32 && valueall[10] == 32) oled.print("K");
if (valueall[9] == 16 && valueall[10] == 32) oled.print("M");
if (valueall[9] == 0 && valueall[10] == 64) oled.print("A");
if (valueall[9] == 64 && valueall[10] == 64) oled.print("mA");
if (valueall[9] == 128 && valueall[10] == 64) oled.print("uA");
if (valueall[9] == 0 && valueall[10] == 2) oled.print("Grad C");
if (valueall[9] == 0 && valueall[10] == 1) oled.print("Grad F");
if (valueall[9] == 0 && valueall[10] == 8) oled.print("Hz");
oled.display();
oled.clear(PAGE);
After 11 posts, don't you think it about time that you help others to help you, and use code tags?
Your problem relates to array bounds.
What will the largest value of variable a be ?
char valuechar[15];
How many values can valuechar[] hold and what are the indices to them ?
    delay(100);
That delay is really needed? Seems counter-intuitive to me: "oh look, there's some input to
read so I'll go to sleep for 100,000 microseconds" - sounds like a recipe for input buffer overflow
