Code compiles, board does not run.
Hi guys! My first post here!
I was following some tutorials, trying to send data from soil moisture, DHT22 and LDR to Thingspeak. My first experiment, without the LDR functions very well. But since I need to use it (and try to “multiplex” with the soil moisture sensor, I am getting just a dead board. Absolutely nothing happens after flash the code. The code compiles without any error, and I also tried to find the problem, both in the code and in the board wiring.
Please, could someone give a look? I really don’t know why I am doing wrong.
// Library DHT22
#include <DHT.h>
// Library ESP
#include <ESP8266WiFi.h>
// Thingspeak API key,
String apiKey = "";                                     //fill w/ api key from thingspeak
const char* ssid = "";                          //fill w/ wifi name
const char* password = "";                       //fill w/ wifi password
const char* server = "api.thingspeak.com";
// DHT22
#define DHTPIN D3 // what pin we’re connected to
DHT dht(DHTPIN, DHT22); //why 15? dht 22, 15
WiFiClient client;
// Variables
int sensorPin = A0;    // input for LDR and rain sensor
int enable1 = D1;      // enable reading LDR
int enable2 = D2;      // enable reading Soil sensor
int sensorValue1 = 0;  // variable to store the value coming from sensor LDR
int sensorValue2 = 0;  // variable to store the value coming from sensor Soil sensor
// Setup
pinMode(enable1, OUTPUT);
pinMode(enable2, OUTPUT);
delay(10);
dht.begin();
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.println(ssid);
Serial.print("..........");
Serial.println("WiFi connected");
// DHT22
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Serial.print("Temperature:      ");
Serial.print(t);
Serial.print(" degrees Celcius ");
Serial.print("Humidity:         ");
Serial.print(h);
Serial.print("%");
// LDR
digitalWrite(enable1, HIGH);
  sensorValue1 = analogRead(sensorPin);
  sensorValue1 = constrain(sensorValue1, 300, 850);
  sensorValue1 = map(sensorValue1, 300, 850, 0, 1023);
  Serial.print("Light intensity: ");
  Serial.println(sensorValue1);
  digitalWrite(enable1, LOW);
  delay(100);
  // novo bloco que pega o input via tradicional: Sensor 2 (Soil Moisture)
 digitalWrite (enable2, HIGH);
  delay (500);
  sensorValue2 = analogRead (sensorPin);
  sensorValue2 = constrain (sensorValue2, 380, 0);
  sensorValue2 = map(sensorValue2, 380, 0, 0, 100);
  Serial.print("Sensor 2 value:  ");
  Serial.println (sensorValue2);
  Serial.println ();
  digitalWrite (enable2, LOW);
  delay (2000);
// Thingspeak
   if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
     String postStr = apiKey;
     postStr += "&field1=";
     postStr += String(t);
     postStr += "&field2=";
     postStr += String(h);
     postStr += "&field3=";
     postStr += String(sensorValue1);
     postStr += "&field4=";
     postStr += String(sensorValue2);
     postStr += "\r\n\r\n\r\n\r\n";
     client.print("POST /update HTTP/1.1\n");
     client.print("Host: api.thingspeak.com\n");
     client.print("Connection: close\n");
     client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
     client.print("Content-Type: application/x-www-form-urlencoded\n");
     client.print("Content-Length: ");
     client.print(postStr.length());
     client.print("\n\n\n\n");
     client.print(postStr);
   client.stop();
          // thingspeak needs minimum 15 sec delay between updates
delay(20000);
I really don't know why I am doing wrong.
I think that meant to say that you don't know what you are doing wrong. I can see some things.
One should not need comments to understand the code.
int lightValue = 0;
int moistValue = 0;
No comments are needed to see which variable holds what value. And, it makes it much more obvious that there is an error if you do:
   lightValue = analogRead(moistPin);
than if you do
   sensorValue1 = analogRead(sensorPin2);
These variables do not enable anything.
They are used to power the LDR circuit or the moisture sensor circuit.
That is not true. You don't have any Serial.print() statements before calling dht.begin() and WiFi.begin(). Both of them could hang, waiting for something to happen that can't. You need to add some more print() calls, to determine exactly where the code stops working.
