Code compiles but working partially
Hii, Please correct this code it's compiling successfully but FIRE ALARM not working rest of the Radar part is working properly.
// Includes the Servo library
#include <Servo.h>.
// Defines Tirg and Echo pins of the Ultrasonic Sensor
const int trigPin = 10;
const int echoPin = 11;
// Variables for the duration and the distance
long duration;
int distance;
//************************** FIRE ALARM PIN
int flamepin = 5;
Servo myServo; // Creates a servo object for controlling the servo motor
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
myServo.attach(12); // Defines on which pin is the servo motor attached
//**************************** FIRE ALARM PINMODE BELOW
pinMode(4, OUTPUT); // defining 4th pin for LED as output
pinMode(6, OUTPUT); // defining 5th pin for LED as output
pinMode(8, OUTPUT); // defining 8th pin for BUZZZER as output
// rotates the servo motor from 15 to 165 degrees
for(int i=15;i<=165;i++){
myServo.write(i);
delay(30);
distance = calculateDistance();// Calls a function for calculating the distance measured by the Ultrasonic sensor for each degree
Serial.print(i); // Sends the current degree into the Serial Port
Serial.print(","); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
Serial.print(distance); // Sends the distance value into the Serial Port
Serial.print("."); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
// Repeats the previous lines from 165 to 15 degrees
for(int i=165;i>15;i--){
myServo.write(i);
delay(30);
Serial.print(i);
Serial.print(",");
Serial.print(".");
// FIRE ALARM PART
int flame = digitalRead(flamepin); // initializing flamepin value to flame which is a variable of int type
if (flame == LOW) // if statement to check condition
digitalWrite (4,HIGH); // SUPPLIED HIGH VOLTAGE TO LED
delay (20);
digitalWrite (6,HIGH);
delay (20);
digitalWrite (8,LOW); // BUZZER SUPPLIED LOW VOLTAGE FOR LOW VOLTAGE TRIGGERING
delay (20);
else if (flame == HIGH)
digitalWrite(8,HIGH);
digitalWrite(6,LOW);
digitalWrite(4,LOW);
delay (10); // delay after loop execution
// Function for calculating the distance measured by the Ultrasonic sensor
int calculateDistance(){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH); // Reads the echoPin, returns the sound wave travel time in microseconds
distance= duration*0.034/2;
return distance;
Please describe "not working".
What is driving the flamepin? In case of a button (or similar), do you use a pull-down or pull-up resistor?
Please modify your post according to the guidelines in How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum point #7.
You forgot 'pinMode(flamepin, INPUT_PULLUP);'.
The flamepin input is only checked after each full cycle of the servo. Is the servo moving as expected?
Note: You don't specify a timeout in your pulseIn() call so the default (1000000 microseconds) is used. If the ultrasonic range detector doesn't get an echo (too close or too far) the pulseIn() will delay a full second. You should see that as a pause in the motion of the servo. Change to " duration = pulseIn(echoPin, HIGH, 30000UL);" to use a 30 millisecond timeout instead of a 1000 millisecond timeout.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.... :slight_smile:
Apart from forgetting to name the pin, and the fact that it's the ninth pin, how about turning the buzzer off?
Just about the lamest thing you could write here.
