can someone write me a code to run a fan as the temperature increases?
i have the components of the arduino uno R3 starter kit
Welcome to the forum
As your topic does not relate directly to the use of IDE 1.x it has been moved to the Programming category of the forum. Please take care when creating topics
As to your question, the forum is not a code writing service unless you are prepared to pay for it. Are you prepared to pay ?
Use the InterNet, @peppe_09
#include <DHT.h>
const int tempPin = 2; // DIO
const int fanPin = 3; // PWM
DHT dht = DHT(tempPin, DHT22);
dht.begin();
pinMode(fanPin , OUTPUT);
float temp = dht.readTemperature(); // Celsius
if (isnan(temp)) return;
int fanSpeed = map(temp, 20, 40, 0, 255);
fanSpeed = constrain(fanSpeed, 0, 255);
analogWrite(fanPin, fanSpeed);
Hi @peppe_09
welcome to the arduino-forum.
Yes I can write such a code.
But only if you would tell what kind of temperature-sensor what kind of voltage and power-consumption your fan has.
Though you did not even use the word "please" I will not write it for you.
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
best regards Stefan
