The following code compiles and all wiring connections seem to work but it does not exit the setup () section; it repeats the Setup() indefinitely.
Setup is followed by several functions (not completely included to save space) before the loop is called. None of the serial monitor control texts in the functions are displayed.
Any advice or comment is appreciated.
include <Wire.h>
#include <ArduCAM.h>
#include "memorysaver.h"
#include <SPI.h>
#include <SD.h>
#include <Adafruit_MMA8451.h> // I2C address for accelerometer = 0x1C or 0x1D
#include <Adafruit_Sensor.h>
#include "RTClib.h"
RTC_DS3231 rtc; // 0x68 = I2C address
#define FRAMES_NUM 0x00
#define SD_CS 10
#define CS 7
String name1 = "I-"; // Image file name, < 8 characters
String name;
bool myCAM_EXIST = false;
//const int MPU = 0x68; //0x68 = I2C address for accelerometer
//double AccX, AccY, AccZ, ToTA = 0;
double AX, AY, AZ;
uint8_t vid, pid; // communication with Arducam
uint8_t temp;
double mx, my, mz = 0;
float TotA=0.005;
//float DTime, STime, ETime; //not needed for final implementation
int i, j, l, lmax = 500; // i = image buffer, j = number of images and file number, l = accelerator reads, lmax = max number of accelerometer reads
// CHANGE TO LAUNCH = 3 for actual implementation
// int Launch = 3; // requires 3 accelerometer readings greater than 14 m/s^2
int Launch = 0; // for testing purposes only
ArduCAM myCAM(OV5642, CS);
Adafruit_MMA8451 mma = Adafruit_MMA8451();
if (! mma.begin()) {
Serial.println("Couldnt start");
while (1);
Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_4_G);
pinMode(A1, OUTPUT);
digitalWrite(A1, LOW); //enables MOSFET (LEDs)
delay(5000);
Wire.begin();
Serial.println(F("ArduCAM Start!"));
// set the CS output:
digitalWrite(CS, HIGH); //pin 7
pinMode(SD_CS, OUTPUT); //pin 10
SPI.begin(); // initialize SPI:
myCAM.write_reg(0x07, 0x80); //Reset the CPLD
delay(100);
//Check if the ArduCAM Mini 5MP PLus SPI bus is OK
while (1) {
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55) {
Serial.print(F("SPI interface Error! temp = "));
Serial.println(temp);
while (1) {}
myCAM_EXIST = true;
if (!(myCAM_EXIST)) {
delay(100);
continue;
} else
Serial.println(F("SPI interface OK."));
break; // exit if SPI is OK
while (!SD.begin(SD_CS)) { //Initialize SD Card - pin 10
Serial.println(F("SD Card Error"));
Serial.println(F("SD Card detected."));
while (1) {
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x42)) {
Serial.println(F("Can't find OV5642 module!"));
continue;
} else
Serial.println(F("OV5642 detected."));
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV5642_set_JPEG_size(OV5642_1600x1200);
myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK); //VSYNC is active HIGH
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
} // end setup
void myCAMSaveToSDFile(ArduCAM myCAM) { // Function takes one picture and saves to SD card
Serial.print("Picture");
byte buf[256];
static int i = 0;
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
bool header0 = false;
File outFile;
myCAM.flush_fifo(); //Flush the FIFO
myCAM.clear_fifo_flag(); //Clear the capture done flag
//Start capture
myCAM.start_capture();
// Serial.println(F("Start Capture"));
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("Capture Done."));
length = myCAM.read_fifo_length();
//Construct a file name
name = "Imag/" + name1 + j + ".jpg"; //Imag is subfolder on SD card
outFile = SD.open(name, O_WRITE | O_CREAT | O_TRUNC); // Open the new file
if (!outFile) {
Serial.println(F("File open failed"));
return;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while (length--) {
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ((temp == 0xD9) && (temp_last == 0xFF)) //If @ end, break while
buf[i++] = temp; //save the last 0XD9
myCAM.CS_HIGH(); //Write the remain bytes in the buffer
outFile.write(buf, i);
outFile.close(); //Close the file
// Serial.println(F("Image saved."));
header0 = false;
i = 0;
if (header0 == true) {
if (i < 256) //Write image data to buffer if not full
buf[i++] = temp;
else {
myCAM.CS_HIGH(); //Write 256 bytes image data to file
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
} else if ((temp == 0xD8) & (temp_last == 0xFF)) {
header0 = true;
buf[i++] = temp_last;
buf[i++] = temp;
void Read_Accel() {
//omitted code
File myFile;
if ((Launch == 0)){
digitalWrite(A1, HIGH); // turns MOSFET on, powers LED's
lmax = 200; // number of accelerometer reads
Read_Accel();
// save accelerometer data to file in folder Accl/
DateTime now = rtc.now();
name = String("Accl/") + "Data" + ".cvs"; // Accl is subfolder on SD card
SD.begin(SD_CS);
myFile = SD.open(name, FILE_WRITE); // Open new file
myFile.print(j);
myFile.print(", ");
myFile.print(l);
myFile.print(", ");
myFile.print(AX);
myFile.print(", ");
myFile.print(AY);
myFile.print(", ");
myFile.print(AZ);
myFile.print(", ");
myFile.print(TotA);
AX = AY = AZ = 0;
myFile.print(now.timestamp(DateTime::TIMESTAMP_FULL));
myFile.print(", ");
myFile.print("Temperature: ");
myFile.print(rtc.getTemperature());
myFile.println(" C");
myFile.close();
if (j < 3000) { // use for specific number of images, here 3000, one image per cycle
Serial.println(j);
myCAMSaveToSDFile(myCAM);
j ++;
delay(100);
lmax = 500;
Read_Accel();
} // End loop
The serial monitor output :
MMA8451 found!
ArduCAM Start!
SPI interface OK.
SD Card detected.
OV5642 detected.
MMA8451 found!
etc.
