Code doesn’t work for new Arduino Nano V3.1 Board
I have a program which works on Nano Old Bootloader. I brought a new Nano which is Nano V3.1.
Same program i'm writing with New Bootloader option. It writes successfully. But doesn't came output on after connection. What is the problem?
Please post a simple sketch that illustrates the problem, using code tags when you do
Many people, including me, will not have the hardware and libraries to test the sketch which is why I asked for a simple sketch and I did ask you to post it here rather than attaching it
What exactly is the problem ?
What output are you expecting ?
What is dmd ?
I assume that you have thoroughly checked all of the connections
Good idea to also provide the forum with a schematic of your connections.
DMD is Dot Matrix Display. Basically P10 display. I am using DMD2 Library.
I attached both picture of Arduino. I have both new or old Arduino.
Old Version is Giving Display and New Version Doesn't show display. This is a GPS Clock.
// Inserting File Library
#include <SPI.h>
#include <DMD2.h>
#include <NMEAGPS.h>
#include <fonts/Arnr17.h>
// PICK ONE OF THESE PORT ALTERNATIVES
// BEST: connect GPS to pins 0 & 1, since you're not using Serial.
//             Requires disconnecting pin 0 to upload new sketch over USB.
#define gpsPort Serial // just an alias for Serial
// 2nd BEST: connect GPS to pins 8 & 9 (on an UNO)
//#include <AltSoftSerial.h>
//AltSoftSerial gpsPort
// 3rd BEST:
//#include <NeoSWSerial.h>
//NeoSWSerial gpsPort(3, 4); // RX, TX
// WORST: SoftwareSerial NOT RECOMMENDED
// Defining Constants
#define Length  2
#define Width 1
// Declaration Variable
SoftDMD  dmd(Length, Width);                  // Length x Width
NMEAGPS gps; // parser
unsigned long previousMillis = 0;        // will store last time LED was updated
unsigned int sim_second = 0;
unsigned int sim_minute = 30;
unsigned int sim_hour = 12;
char last_second_dv = '0';
char last_minute_dv = '0';
char last_hour_dv = '0';
char last_second_chuc = '0';
char last_minute_chuc = '0';
char last_hour_chuc = '0';
bool enable_second_dv = false;
bool enable_minute_dv = false;
bool enable_hour_dv = false;
bool enable_second_chuc = false;
bool enable_minute_chuc = false;
bool enable_hour_chuc = false;
bool last_enable_second_dv = true;
bool last_enable_minute_dv = true;
bool last_enable_hour_dv = true;
bool last_enable_second_chuc = true;
bool last_enable_minute_chuc = true;
bool last_enable_hour_chuc = true;
int fontHeightGlobal = 0;
int fontWidthGlobal = 0;
unsigned int anim_speed_global = 40;
// Set these values to the offset of your timezone from GMT
static const int32_t          zone_hours   = +6L; // BST
static const int32_t          zone_minutes =  0L; // usually zero
static const NeoGPS::clock_t  zone_offset  =
  zone_hours   * NeoGPS::SECONDS_PER_HOUR +
  zone_minutes * NeoGPS::SECONDS_PER_MINUTE;
void adjustTime( NeoGPS::time_t & dt )
  NeoGPS::clock_t seconds = dt; // convert date/time structure to seconds
  //  First, offset from UTC to the local timezone
  seconds += zone_offset;
  dt = seconds; // convert seconds back to a date/time structure
} // adjustTime
void char_write(int px, int py, uint8_t* font, char current )
  //  int fontWidth = dmd.charWidth(current);
  //  int fontHeight = font[3];
  //  DMDFrame scrollFrame = dmd.subFrame(px, py, fontWidth, fontHeight);
  //  scrollFrame.selectFont(font);
  //  scrollFrame.fillScreen(false);
  //  scrollFrame.drawChar(0, 0, current);
  //  dmd.copyFrame(scrollFrame, px, py);
  dmd.drawChar(px, py, current);
void char_over_write_animation_step(int px, int py, bool enable, uint8_t* font, char current, char next, int i)
  //  int currentWidth = dmd.charWidth(current);
  //  int nextWidth = dmd.charWidth(next, font);
  //  int fontWidth = (currentWidth >= nextWidth) ? currentWidth : nextWidth;
  //  unsigned int offset_x = fontWidth;
  //  unsigned int offset_y = fontHeight;
  //  if (enable) {
  //    scrollFrame.drawLine(0, i, offset_x - 1, i, GRAPHICS_OFF);
  //    scrollFrame.drawChar(0, i - offset_y  , next);
  //  } else {
  //    scrollFrame.drawChar(0, 0 , next);
  if (enable) {
    dmd.drawChar(px, i - fontHeightGlobal + py  , next);
    dmd.drawChar(px, py , next);
void run_animation(char *dmdBuff) {
  char  check_second_dv = dmdBuff[7];
  char  check_second_chuc = dmdBuff[6];
  char  check_minute_dv = dmdBuff[4];
  char  check_minute_chuc = dmdBuff[3];
  char  check_hour_dv = dmdBuff[1];
  char  check_hour_chuc = dmdBuff[0];
  enable_second_dv =  (check_second_dv != last_second_dv) ? true : false;
  enable_second_chuc =  (check_second_chuc != last_second_chuc) ? true : false;
  enable_minute_dv =  (check_minute_dv != last_minute_dv) ? true : false;
  enable_minute_chuc =  (check_minute_chuc != last_minute_chuc) ? true : false;
  enable_hour_dv =  (check_hour_dv != last_hour_dv) ? true : false;
  enable_hour_chuc =  (check_hour_chuc != last_hour_chuc) ? true : false;
  //Write first
  int last_offset = 1;
  int offset = 0;
  int number_animation = 0;
  if (!enable_hour_chuc) {
    if (last_enable_hour_chuc != enable_hour_chuc) {
      last_enable_hour_chuc = enable_hour_chuc;
      char_write(last_offset, 0, Arnr17, last_hour_chuc);
  else {
    number_animation++;
  offset = dmd.charWidth(last_hour_chuc);
  last_offset =  last_offset + 1 + offset;
  if (!enable_hour_dv) {
    if (last_enable_hour_dv != enable_hour_dv) {
      last_enable_hour_dv = enable_hour_dv;
      char_write(last_offset , 0, Arnr17, last_hour_dv);
  else {
    number_animation++;
  offset = dmd.charWidth(last_hour_dv);
  char_write(last_offset , 0, Arnr17, ':');
  offset = dmd.charWidth(':');
  if (!enable_minute_chuc) {
    if (last_enable_minute_chuc != enable_minute_chuc) {
      last_enable_minute_chuc = enable_minute_chuc;
      char_write(last_offset , 0,  Arnr17, last_minute_chuc );
  else {
    number_animation++;
  offset = dmd.charWidth(last_minute_chuc);
  if (!enable_minute_dv) {
    if (last_enable_minute_dv != enable_minute_dv) {
      last_enable_minute_dv = enable_minute_dv;
      char_write(last_offset , 0, Arnr17, last_minute_dv);
  else {
    number_animation++;
  offset = dmd.charWidth(last_minute_dv);
  if (!enable_second_chuc) {
    if (last_enable_second_chuc != enable_second_chuc) {
      last_enable_second_chuc = enable_second_chuc;
      char_write(last_offset , 0, Arnr17, last_second_chuc);
  else {
    number_animation++;
  offset = dmd.charWidth(last_second_chuc);
  if (!enable_second_dv) {
    if (last_enable_second_dv != enable_second_dv) {
      last_enable_second_dv = enable_second_dv;
      char_write(last_offset , 0, Arnr17, last_second_dv);
  else {
    number_animation++;
  int new_anim_speed = anim_speed_global - 4 * number_animation; // (anim_speed_global / number_animation) * 1.5;
  for (int i = 0; i <= fontHeightGlobal; i++)
    int offset = 0;
    if (enable_hour_chuc) {
      char_over_write_animation_step(last_offset, 0, enable_hour_chuc, Arnr17, last_hour_chuc, check_hour_chuc, i);
    if (enable_hour_dv) {
      char_over_write_animation_step(last_offset , 0, enable_hour_dv, Arnr17, last_hour_dv, check_hour_dv, i);
    //        char_over_write_animation_step(last_offset , 0, false, Arnr17, ':', ':', i);
    if (enable_minute_chuc) {
      char_over_write_animation_step(last_offset , 0, enable_minute_chuc, Arnr17, last_minute_chuc, check_minute_chuc, i);
    if (enable_minute_dv) {
      char_over_write_animation_step(last_offset , 0, enable_minute_dv, Arnr17, last_minute_dv, check_minute_dv, i);
    if (enable_second_chuc) {
      char_over_write_animation_step(last_offset , 0, enable_second_chuc, Arnr17, last_second_chuc, check_second_chuc, i);
    if (enable_second_dv) {
      char_over_write_animation_step(last_offset , 0, enable_second_dv, Arnr17, last_second_dv, check_second_dv, i);
    delay(new_anim_speed);
  if (enable_second_dv)last_second_dv = check_second_dv;
  if (enable_second_chuc)last_second_chuc = check_second_chuc;
  if (enable_minute_dv)last_minute_dv = check_minute_dv;
  if (enable_minute_chuc)last_minute_chuc = check_minute_chuc;
  if (enable_hour_dv)last_hour_dv = check_hour_dv;
  if (enable_hour_chuc)last_hour_chuc = check_hour_chuc;
  dmd.setBrightness(100);
  uint8_t* font = Arnr17;
  dmd.selectFont(font);
  dmd.begin();
  dmd.clearScreen();
  gpsPort.begin(9600);
  fontHeightGlobal = font[3];
  fontWidthGlobal = dmd.charWidth('8');
//  anim_speed_global = 50;//400 / fontHeightGlobal;
  if (gps.available( gpsPort )) {
    gps_fix fix = gps.read();
    if (fix.valid.time) {
      adjustTime( fix.dateTime );
      // UTC_ind_zone_time
      char dmdBuff[10];
      sprintf_P( dmdBuff, PSTR("%02d:%02d:%02d"),
                 fix.dateTime.hours, fix.dateTime.minutes, fix.dateTime.seconds );
      //      dmd.drawString(1, 0, dmdBuff);
      run_animation(dmdBuff);
//  else//Simulator
//    unsigned long currentMillis = millis();
//    if (currentMillis - previousMillis >= 1000) {
//      previousMillis = currentMillis;
//      sim_second++;
//      if (sim_second > 59) {
//        sim_second = 0;
//        sim_minute ++;
//        if (sim_minute > 59) {
//          sim_minute = 0;
//          sim_hour++;
//          if (sim_hour > 23) {
//            sim_hour = 0;
//      char dmdBuff[10];
//      sprintf_P( dmdBuff, PSTR("%02d:%02d:%02d"),
//                 sim_hour , sim_minute, sim_second );
//      run_animation(dmdBuff);
Please see this give me solution! Thanks.
