Code doesn't display the sensor readings
Hey there,
So I am having difficulty with displaying my sensor readings on the LCD using this code:
#define redLED 9 //define the LED pins
#define greenLED 12
int buzzer = 22;
int smokeA0 = A6;
int sensorThreshold = 600;
int analogSensor=analogRead(smokeA0);
 char gas ;
char* password ="1160"; //create a password
int place = 0; //keypad position
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the symbols on the buttons of the keypad
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins [rows] = {28, 29, 30, 31}; //pins of the keypad
byte colPins [cols] = {32, 33, 34,35};
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* CS=*/ 10, /* reset=*/17);
void setup(){
  u8g2.begin();
  u8g2.enableUTF8Print();
  u8g2.setFont(u8g2_font_helvB10_tf);
  u8g2.setColorIndex(1);
  pinMode(redLED, OUTPUT);  //set the LED as an output
  pinMode(greenLED, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(smokeA0, INPUT);
  setLocked (true); //state of the password
void secondscreen(){
    u8g2.setCursor(15, 20);
    u8g2.print("Home Security");
       delay(6000);
void draw(){
  u8g2.drawFrame(0,0,128,31);
  u8g2.drawFrame(0,33,128,31);
  u8g2.setCursor(32, 25);
  u8g2.print("Welcome");
  u8g2.setCursor(10, 50);
  u8g2.print(" Enter Password");
void thirdscreen(){
  u8g2.drawStr( 15, 13, "Gas/Smoke:");
  u8g2.setCursor(15, 28);
  u8g2.print(analogSensor);
  u8g2.drawUTF8(76, 28, "PPM");
void setLocked(int locked){
  if(locked){
    digitalWrite(redLED, HIGH);
    digitalWrite(greenLED, LOW);
    else{
      digitalWrite(redLED, LOW);
      digitalWrite(greenLED, HIGH);
void loop(){
    u8g2.firstPage();
  do {
    draw();
  } while( u8g2.nextPage() );
  char whichKey = myKeypad.getKey(); //define which key is pressed with getKey
  if(whichKey == '*' || whichKey == '#' || whichKey == 'A' ||       //define invalid keys
  whichKey == 'B' || whichKey == 'C' || whichKey == 'D'){
    place=0;
    setLocked (true);
    u8g2.firstPage();
  do {
       u8g2.setCursor(20, 30);
    u8g2.print("  Invalid Key!");
     u8g2.clear();
  if(whichKey == password [place]){
    place ++;
  if(place == 4){
    setLocked (false);
    u8g2.clear();
      u8g2.firstPage();
  do {
  u8g2.setCursor(20, 35);
    u8g2.print("*** Verified ***");
    delay(3000);
     u8g2.clear();
         u8g2.firstPage();
  do {
secondscreen();
             u8g2.firstPage();
  do {
thirdscreen();
if (analogSensor < sensorThreshold)
        tone(buzzer, 1000, 200);
      noTone(buzzer);
delay(10000);
I’m basically trying to enter a password on a keypad then display a message if the password is correct then display the gas sensor readings on the LCD. The readings I get on the LCD is “0”.
However when I test the gas sensor, it is fine and does display readings normally using this code:
#include <U8g2lib.h>
#include <U8x8lib.h>
int LED1 = 9;
int LED2 = 12;
int buzzer = 22;
int smokeA0 = A6;
int sensorThreshold = 630;
 int analogSensor;
  u8g2.begin();
  pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
void draw(){
  u8g2.drawStr( 20, 13, "Gas/Smoke:");
u8g2.setCursor(35, 28);
  u8g2.drawUTF8(65, 28, "PPM");
  u8g2.firstPage();
  do {
    draw();
analogSensor = analogRead(smokeA0);
if (analogSensor > sensorThreshold)
digitalWrite(LED1, HIGH);
digitalWrite(LED2, LOW);
digitalWrite(LED1, LOW);
digitalWrite(LED2, HIGH);
noTone(buzzer);
I’m not sure where I went wrong.
Another problem I face is that the LCD takes a lot of time to display the “Home Security” message even though “Verified” is instantly displayed.
Note: I’m using a 128x64 LCD
try moving "read analogsensor" to within the loop
knut_ny:
I did, it's still showing '0'.
