Code doesn't run infinitely!
I'm having trouble with my code!
I'm using an ACS712-30A Current sensor, along with an arduino nano, for a project. I take readings every second but my code doesn't run infinitely. I get 16 readings then it stops, so I have push the reset button on the nano for it to restart!
  1. What exactly could be the problem? - I've been reading and the most talked about problem is memory leak!
  2. How do i resolve the issue? - Be it memory leak or any other problem.
Here is my code for reference!!
#define ACS712 A0
int lastData = 0;
int dataSum = 0;
int Count = 0;
float mean;
float value;
float Voltage;
float Current;
float Power;
float Consumption;
float vpc = 4.8828125; // approx. voltage per count
  Serial.begin (115200);
  // If statement to take measurements:
  if (millis() > lastData + 1) {
    dataSum += sq(analogRead(ACS712) - 512);
    Count++;
    lastData = millis();
  // If statement to make calculations.
  if (Count == 1000) {
    // To get the RMS of the data.
    mean = dataSum / Count;
    value = sqrt(mean);
    // To get the Voltage (in volts) consumed.
    Voltage = value * vpc;
    // To get the Current (in amps) consumed.
    Current = Voltage / 66;
    // To get the Power (in watts) consumed.
    Power = Current * 240;
    Consumption = Power / 1000;
    Serial.println(String(Voltage) + "V ");
    Serial.println(String(Current) + "A ");
    Serial.println(String(Power) + "Watts");
    Serial.println(String(Consumption) + "kWh");
    dataSum = 0;
    Count = 0;
Thanks...
You have ‘lastData’ set to data type ‘int’
millis() returns ‘unsigned long’
You should review the Blink Without Delay example in the examples section in the IDE.
larryd:
Thanks...
It worked like a charm!!
So happy... It's been a tough week because of that!
