Code doesn't work and in all the places I looked I can't seem to find a solution
Okay first of all hello friends, it's my first time posting here, yes I have read the required read before posting reading material and I have looked in a great deal of other sources but I can't seem to find what I am looking for.
So I basically have 2 questions, 1st what is wrong with my code (I think in logical coding reasoning there must be something wrong) I am not a programmer so I only understand the basics so I cant seem to find what I'm doing wrong, the second question is are the things that I could have written more smartly and if sow how?
What I am trying to do is, I'm trying to make a moisture checker for plants (with some tinkering to go it's supposed to work on 4 different plants) and the idea is that when I push the button it goes and turns on the LED for the first plant, then checks the moisture sensor and on the basis of that it moves the pointer on a servo motor. It does the exact same if I push the button again but it's supposed to light up a different LED and I'll later on put different types of numbers required for plants. So I push again and it repeats almost the same process but for a different plant with different numbers and a different LED. If I pushed the button 4 times it should go back to the first mode again. I wrote this code but it doesn't seem to work:
#include <Servo.h>
// servo
int positie = 0;
Servo servo_5;
// water sensor
int sensorPin = A1;
int sensorValue = 0;
//counts number of times button pressed
int counter = 0;
// lampjes
const int LED1 = 8;           //number of led pin
const int LED2 = 7;
const int LED3 = 6;
const int LED4 = 4;
// button
const int buttonPin = 2;     // the number of the pushbutton pin
int buttonState = 0;
// monitor
// watersensor
  pinMode(sensorPin, INPUT);
//button
  pinMode(buttonPin, INPUT);
//servo
  servo_5.attach(5);
  //led
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  buttonState = digitalRead(buttonPin);
  //is this right??
  counter = digitalRead(buttonPin);
  if (buttonState = HIGH) {
    (counter ++ ) ;          // every time button is pushed buttonState adds up
    if ( counter == 5) { //reset counter
     ( counter = 0); }
  if (counter = 1) {
  digitalWrite(LED1, HIGH);
  positie = map(sensorValue, 0, 950, 0, 180);
  servo_5.write(positie);
  Serial.println(sensorValue);
  delay(10); // Delay a little bit to improve simulation performance
  if (counter = 2) {
  digitalWrite(LED2, HIGH);
  if (counter = 3) {
  digitalWrite(LED3, HIGH);
  if (counter = 4) {
I work with a Arduino Uno with a grove shield, grove moisture sensor, grove led, a normal servo motor and a grove button.
It's very unlikely that at least on the Arduino things aren't wired correctly so it's really about the code
= for assignment, == for comparison
Also, if you read a button and assign the value to "counter" then "counter" is only ever going to be 1 or 0.
the state change detection tutorial shows how to do button press counting.
