So I’m creating a code that uses a rotary encoder to cycle through all of the colors in the RGB color spectrum at full brightness. I wanted to create this section of code that does that when the code turns on independent of the encoder to give the product a sort of “configuration” feel at the beginning of the code. To do this, I created a function that does it and included it at the end of the setup code. I plan on using this later in the loop code.
The problem is that the function doesn’t work unless I have a Serial.println() line in each while loop. Here is the code:
void configure(){
r=255;
g=0;
b=0;
while (g<255){
Serial.println(g);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
g+=1;
while (r>0){
Serial.println(r);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
r-=1;
while (b<255){
Serial.println(b);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
b+=1;
while (g>0){
Serial.println(g);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
g-=1;
while (r<255){
Serial.println(r);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
r+=1;
while (b>0){
Serial.println(b);
analogWrite(9, r);
analogWrite(10, g);
analogWrite(11, b);
analogWrite(3, r);
analogWrite(5, g);
analogWrite(6, b);
b-=1;
The code doesn’t work without the Serial.println() lines. Also, the led starts shining at around a green-yellow color when it’s supposed to start on red.
I’m coding this on a nano with the intention of putting this on a pcb.
I honestly have no idea why it’s doing this.
