CODE doesn't workd , please HEEEELP !!!!
Hi, this is the CODE:
int val=0;
pinMode(1, OUTPUT);
pinMode(3, OUTPUT);
pinMode(7, INPUT);
digitalWrite(1, 1);
val=digitalRead(7);
digitalWrite(3, val);
digitalWrite(1, 0);
digitalWrite(3, 0);
By this way I need to read the status of the pin 1 into the pin 7 and as consequence swithc on the led in pin 3. I don’t understand why it doesn’t works. Probably the proble is in the connection for the pin 7 ???
I attach the schematic.
Thanks in advance for any precious help, and sorry for my bad english ? :slight_smile:
What is connected to pin 1 and why are you using it when it is normally used by the hardware serial class ?
I see that you don't have any current limiting resistors in series with the LEDs. Is this deliberate ?
I don't understand why it doesn't works.
What happens when you run it ?
From the diagram, it appears to be an LED. Why OP is expecting that to act as an input device is a mystery. How that is to be powered is a mystery, too.
Please add some resistors between the LEDs and ground or the LEDS and the Arduino pins. It might be healthier for the Arduino :wink:
And from the schematic, you are reading the status of pin 3 into pin 7 (as they are the two that are connected together).
