Code edit help speed and distance cruise control value
Hello i want to ask about this project if it is possible to make from the potentiometers of the speed and distance minimum 1m and maximum 50 meters and for the speed from 1 km to 30 ?
I managed to change it from minimum 5km and 8m distance but the maximum values are still too high and dont know what to change.
Here is my edited code:
//#PINGSENSOR - trig pin 6
//#echo pin 7
/* Code for Adaptive Cruise Control System(ACC)*/
// Including Library Files:
//#include <LiquidCrystal.h>
//included the library of I2C LCD
LiquidCrystal_I2C lcd(0x3F, 16, 2);
#include<Servo.h>
/* Macro Definition  */
#define massSensor        A0
#define cruiseSpeedDial     A2
#define cruiseDistanceDial    A3
/* Object Declaration */
Servo myservo1, myservo2;
/* Global Variables Declaration*/
const int TrigPin = 6;
const int EchoPin = 7;
const int servo1 = 9;     //Pin connected to the Throttle Servo
const int servo2 = 10;    //Pin connected to the Brake Servo
const int start = 8;      //Pin connected to the ACC Master Control Switch
const int engineRPM = 11;   //Pin connected to the Motor
const int speedSensor = 3;  //Pin connected to Simulated Car Speed Sensor
int distance = 0;       //Variable to store the distance of the leading vehicle from the host vehicle
int distanceSet = 0;      //Variable to store the minimum distance set by the user, that is to be maintained in ACC mode
int speed = 0;        //Variable to store the speed of the Host vehicle
int speedSet = 0;       //Variable to store the cruise speed from the user
int tempSpeedSet = 0;     //Variable to store temporary speed value
int mass = 0;         //Variable to store the total mass of the vehicle including passengers
int servoValue = 0;     //Variable to store angle values of servos
long duration = 0;      //Variable to store the Pulse Duration in Radar
double error = 0;       //Variable to store error in speed
double lastError = 0;     //Variable to store the last error in speed
double cumError = 0;      //Variable to store the cummulative error over time
double rateError = 0;     //Variable to store the change of rate of error over time
double outputPWM = 0;     //Final Output to be given to the Motors
double kp = 15;       //Variable to store the Propotional Gain
double ki = 1;        //Variable to store the Integral Gain
double kd = 0.5;        //Variable to store the Derivative Gain
double force = 0;       //Variable to store the overall force acting on the simulated car
double friction = 0;      //Variable to store the frictional force acted upon the car
double drag = 0;        //Variable to store the drag force acted upon the car
int brakeForce = 0;   //Variable to store the BreakForce needed to stop the car
double acceleration = 0;    //Variable to store the acceleration of the car
/* Function Prototypes*/
void defaultPos(void);      //Function that runs when system is Off
void startACC(void);      //Function that runs when system is On
void getDistance(void);     //Function to set the minimum allowed trailing distance from the user
void getSpeed(void);      //Function to set the cruise speed from the user
void checkRadar(void);      //Function to get vehicle position at front
void getMass(void);       //Function to get the vehicle and passenger Mass
void getSimulatedSpeed(void); //Function to get the Simulated vehicle speed
void PID(void);         //Function to Control the PWM output using PID Control Algorithm
void simulateCar(void);     //Function to simulate the linear movement of a car
void cutSpeed(void);      //Function to reduce vehicle speed due to incoming traffic
void brake(void);       //Function to calculate brake force to stop the vehicle
/* Function Definitions*/
  //  Serial.begin(9600);
 lcd.init(); // initialize the lcd
  lcd.backlight();
  lcd.clear();
  lcd.setCursor(4,0);
  pinMode(cruiseSpeedDial, INPUT);
  pinMode(cruiseDistanceDial, INPUT);
  pinMode(speedSensor, INPUT);
  pinMode(start, INPUT);
  pinMode(engineRPM, OUTPUT);
  myservo1.attach(9);
  myservo2.attach(10);
  myservo1.write(90);
  delay(15);
  myservo2.write(90);
  delay(15);
  lcd.write("Adaptive Cruise");
  lcd.setCursor(0, 1);
  lcd.write(" Control System");
  delay(1500);
  myservo1.write(0);
  delay(15);
  myservo2.write(0);
  delay(15);
  delay(1500);
  lcd.clear();
  lcd.setCursor(7, 1);
  lcd.write("OFF ");
  lcd.setCursor(11, 0);
  lcd.print(speed);
  lcd.write("Km ");
  getSpeed();
  getDistance();
  checkRadar();
  getMass();
  distanceSet = (analogRead(cruiseDistanceDial) * 0.1953125) + 1;
  lcd.print(distanceSet);
  lcd.print("m ");
void getSpeed(void)
  speedSet = (analogRead(cruiseSpeedDial) * 0.1171875) + 1;
  lcd.setCursor(0, 0);
  lcd.print(speedSet);
  lcd.print("Km ");
void getMass(void)
  mass = (analogRead(massSensor) * 0.48828125) + 1500;
  lcd.setCursor(6, 0);
  lcd.print(mass);
void cutSpeed(void)
  tempSpeedSet = speedSet - ((5 - distance) * 0.003 * speedSet);
  if (speedSet != tempSpeedSet)
    speedSet = tempSpeedSet;
void brake(void)
  brakeForce = (mass * ((speed * speed) + 1)) / (2 * distance);
  outputPWM = 0;
void PID(void)
  error = speedSet - speed;
  cumError += error * 0.8;  //0.8 is the simulation time
  rateError = (error - lastError) / 0.8;
  outputPWM = (kp * error) + (ki * cumError) + (kd * rateError);
  lastError = error;
  analogWrite(engineRPM, outputPWM);
  friction = 0.7 * mass * 9.8;  //0.7 is the assumed coefficint of friction
  drag = (0.3 * 1.225 * (speed * speed) * 4) / 2; //03 is the assumed drag coefficient,
  //1.225 is the assumed density of the car
  //4 square metres is the assumed surface area
  force = (outputPWM * 78.125) - brakeForce - friction - drag;
  acceleration = force / mass;
  speed += acceleration * 0.8;
  if (speed < 0)
    speed = 0;
  lcd.print(speed);
  lcd.print("Km ");
  servoValue = (outputPWM * 0.703125);
  myservo1.write(servoValue);
  delay(15);
  servoValue = brakeForce;
  myservo2.write(servoValue);
  pinMode(TrigPin, OUTPUT);
  pinMode(EchoPin, INPUT);
  digitalWrite(TrigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(TrigPin, HIGH);
  delayMicroseconds(5);
  duration = pulseIn(EchoPin, HIGH);
  distance = duration/29/2;
  // convert the time into a distance
  distance = duration / 29 / 2;
  lcd.setCursor(11, 1);
  lcd.print(distance);
  lcd.print("m ");
void startACC(void)
  getSpeed();
  getDistance();
  getMass();
  lcd.print("ON ");
  checkRadar();
  if (distance >= distanceSet)
    brakeForce = 0;
    PID();
    simulateCar();
  else if ((distance < distanceSet) && (distance >= 30))
    brakeForce = 0;
    cutSpeed();
    PID();
    simulateCar();
    brake();
    brakeForce += 30;
    simulateCar();
  if (digitalRead(start) == HIGH) //Checking for switch On
    startACC();
    defaultPos();
Read and use this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
What are You taking about? Forum helpers doesn't have the intuition of Your mother.
Isn't it just a question of changing the magic numbers you're using to multiply the potentiometer readings by?
For example, the distance number should be more like 0.0478983.
