[Code] edited
Original code. Senor working but I cant get the float switch to shut the relay off when closed
//this code is made to control hydroponic garden water level
const int ir_sensor = 5; // infread water leve sensor digital pin 5
const int jug_led = 10; // low water red led
const int safety_switch = 11; ; // float inside water container
const int pbr = 12; // power brick relay (pump) digital pin 12
pinMode(ir_sensor, INPUT);
pinMode(safety_switch, INPUT);
pinMode(pbr, OUTPUT);
pinMode(jug_led, OUTPUT);
digitalWrite(ir_sensor, LOW); // if the sensor is wet it will not turn on
if (ir_sensor < HIGH) { // infread sensor is wet
digitalWrite(pbr, HIGH); //turns on power brick relay
digitalWrite(ir_sensor, LOW); // shuts relay off now filled to the right water level
digitalWrite(safety_switch, HIGH); // water tank float is in the has water position
if (safety_switch < LOW) { // water tank float is no longer full
digitalWrite(pbr, LOW); // stops the power brink relay to pervent pump from running, maybe fire
if (safety_switch< LOW){ // float has detremand low water level
digitalWrite(jug_led,HIGH); // turns on anoying red led to alert idiots its empty
}else{
digitalWrite(jug_led,LOW); // led is no on because idiots filled me
// delay will be added after test
Edited
// this code is made to control hydroponic garden water level
const int ir_sensor = 7; // infread water leve sensor digital pin 5
const int safety_switch = 12; ; // float inside water container
const int pbr = 11; // power brick relay (pump) digital pin 12
digitalWrite(pbr,LOW);
digitalWrite(jug_led, LOW);
int led = digitalRead(ir_sensor);
if (led) { // infread sensor is wet
digitalWrite(pbr, LOW); //turns on power brick relay
digitalWrite(pbr, HIGH); // shuts relay off now filled to the right water level
digitalRead(safety_switch); // water tank float is in the has water position
if (safety_switch, HIGH){ //ater tank float is no longer full
digitalWrite(pbr, LOW); // water tank float is in the has water position
delay(50);
That is not how you test whether a pin is in a HIGH state
HINT : you need to read the state of the digital pin
I just started over and add things instead of having fix the whole thing at once
UKHeliBob:
I think I am getting confused on how I should be writing the globals. Should be using # define?
centerpoo:
The problem has nothing to do with declaring variables or using #defines
Do a Google search for if statements in C and look at the examples
and use "digitalRead()" to get the value of the pin.
Another problem Is I just checked the board and used a different one with headers lose. Tryed the button blink example wasn't working.
Plus the switch has internal resistance 400k just realized it's analog.
by now "I" am getting confused..
Deva_Rishi:
Basically I didn't know I was talking about but the board I was using was the original uno. The plastic header are 4 different headers and because it's not az strong as the new ones, that are just 2 header rails its was weaker and broke. It was a gift, it the board I use first because if I blow it up, i wouldn't care.
And lastly I didn't really comprehend the pull up resistor logic. Because it's a switch I needed a 10 k resistor, I have it reading in digital now. It's working now. I just need to add the led.
