Code entering wrong if sentences
Hi everyone, I’m trying to do a Bluetooth based temperature and humidity reader, with this measurements the Arduino activates or deactivates a rele. The problem is that when I add other if inside the if from the bluetooth availability, I get all the print, even the ones that aren’t supposed to show.
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
#include <SoftwareSerial.h>
SoftwareSerial BT(10,11);
int pin_rele = 4;
float t_set = 25;
char in_char;
  BT.begin(9600);
  Serial.println(F("Inicializando DHT 11"));
  dht.begin();
  pinMode(4,OUTPUT);
  float t = dht.readTemperature();
  float h = dht.readHumidity();
  if (BT.available()){
    delay(10);
    in_char = BT.read();
    if (in_char = 'l'){
      Serial.print("Temperatura: ");
      Serial.print(t);
      Serial.println("°C");
      Serial.print("Humedad: ");
      Serial.print(h);
      Serial.println("%");
      delay(20);
      BT.print("Temperatura: ");
      BT.print(t);
      BT.println("°C");
      BT.print("Humedad: ");
      BT.print(h);
      BT.println("%");
    if (in_char = 's' ){
      BT.print("t_set es: ");
      BT.print(t_set);
      BT.println("°C");
    if (t>t_set+2 || t<t_set-2){
      digitalWrite(pin_rele,HIGH);
    else{
      digitalWrite(pin_rele,LOW);
So, if I enter a l I should get the print of Temperature and Humidity from the first if sentence, but I’m getting also the second one, that’s supposed to show when I type an s.
I don’t know what’s happening here, so any clue will be good recieved.
Thanks.
At the very least, you are using assignment
when what you want is comparison
in you if statements.
HTH
a7
You are confusing between assignment operator (=) and compassion operator (==) in if statement
Haha, yes C/C++ really could use a compassion operator.
a7
newbie issues... jajajaja thanks to you all.
