Code error: ARDUINO WIFI RGB LAMP
Hello, i'm totally new on arduino. I've a project for school to do and i choose "ARDUINO WIFI RGB LAMP".
But the project is quite old ( from 2009) so the library changes and the code wont work anymore. I tried to change #include in #include but i give me some new error:
Sorry for my english and for the format i'm new here :slight_smile:
I put the .ino file in attachement
In file included from C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:27,
from sketch_nov27a.ino:19:
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Server.h:23: error: expected class-name before '{' token
In file included from sketch_nov27a.ino:19:
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:33: error: 'uint16_t' does not name a type
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:36: error: field 'uint16_t' has incomplete type
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:37: error: 'uint8_t' has not been declared
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:39: error: 'size_t' does not name a type
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:40: error: 'size_t' does not name a type
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:41: error: 'uint8_t' does not name a type
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:43: error: 'Print' has not been declared
C:\Program Files (x86)\Arduino\libraries\WiFi/WiFiServer.h:37: error: 'NULL' was not declared in this scope
sketch_nov27a.ino: In function 'void setup()':
sketch_nov27a:179: error: expected unqualified-id before '.' token
sketch_nov27a:182: error: expected unqualified-id before '.' token
sketch_nov27a.ino: In function 'void loop()':
sketch_nov27a:198: error: expected unqualified-id before '.' token
sketch_nov27a.ino: In function 'void printWebPage2()':
sketch_nov27a:330: error: expected unqualified-id before '.' token
sketch_nov27a:330: error: expected primary-expression before ')' token
sketch_nov27a:330: error: expected ;' before ')' token sketch_nov27a.ino: In function 'void printWebPage()': sketch_nov27a:346: error: expected unqualified-id before '.' token sketch_nov27a:346: error: expected primary-expression before ')' token sketch_nov27a:346: error: expected ;' before ')' token
sketch_nov27a:368: error: expected unqualified-id before '.' token
sketch_nov27a:368: error: expected primary-expression before ')' token
sketch_nov27a:368: error: expected `;' before ')' token
sketch_nov27a:373: error: expected unqualified-id before '.' token
sketch_nov27a:375: error: expected unqualified-id before '.' token
sketch_nov27a:377: error: expected unqualified-id before '.' token
sketch_nov27a:379: error: expected unqualified-id before '.' token
sketch_nov27a:381: error: expected unqualified-id before '.' token
sketch_nov27a:385: error: expected unqualified-id before '.' token
sketch_nov27a:386: error: expected unqualified-id before '.' token
sketch_nov27a:387: error: expected unqualified-id before '.' token
sketch_nov27a:388: error: expected unqualified-id before '.' token
sketch_nov27a:389: error: expected unqualified-id before '.' token
sketch_nov27a:390: error: expected unqualified-id before '.' token
sketch_nov27a:391: error: expected unqualified-id before '.' token
sketch_nov27a:392: error: expected unqualified-id before '.' token
sketch_nov27a:393: error: expected unqualified-id before '.' token
sketch_nov27a:398: error: expected unqualified-id before '.' token
sketch_nov27a:404: error: expected unqualified-id before '.' token
WiFiLamp.ino (17.6 KB)
