Code error causing me to lose Arduino (Micro) boards (when uploading code)
I just cleaned up the code a bit making it a little bit easier to understand. The pulse sensor code (which is giving me issues) is surrounded by stars "******". The problem started ONLY after I added this new part of the code to my LCD/temp sensor code.
int sensorPin = A0;
// PULSE SENSOR CODE
int pulsePin = A1;                 // Pulse Sensor purple wire connected to analog pin A1
int blinkPin = 13;                // pin to blink led at each beat
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM;                   // used to hold the pulse rate
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // holds the time between beats, must be seeded!
volatile boolean Pulse = false;     // true when pulse wave is high, false when it's low
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
// included in the library code:
#include <Adafruit_CharacterOLED.h>
Adafruit_CharacterOLED lcd(OLED_V2, 4, 5, 6, 7, 8, 9, 10);
//PULSE CODE (to make pin led blink to heartbeat )
    pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
     interruptSetup();
  // Print a message to the LCD.
  lcd.begin(16, 2);
  lcd.print("Jose Mendes");
  // lcd.setCursor(1, 1);        //2nd line
  // lcd.print("line 2");
 //getting the voltage reading from the temperature sensor
 int reading = analogRead(sensorPin);
 // converting that reading to voltage, for 3.3v arduino use 3.3
 float voltage = reading * 5.0;
 voltage /= 1024.0;
 // print out the voltage
 Serial.print(voltage); Serial.println(" volts");
 // now print out the temperature
 float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset
                                               //to degrees ((voltage - 500mV) times 100)
 Serial.print(temperatureC); Serial.println(" degrees C");
 // now convert to Fahrenheit
 float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
 Serial.print(temperatureF); Serial.println(" degrees F");
  delay(5000);                                     //waiting a second
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(temperatureF); lcd.print(" deg. F");
// MORE PULSE CODE FOR BPM
  if (QS == true){ // Quantified Self flag is true when arduino finds a heartbeat
Serial.println(BPM); // only print BPM variable without the leading 'B'
QS = false; // reset the Quantified Self flag for next time
delay(20); // take a break
