Code error- conversion from const char to char
Hi
I want to display image on 1.8 lcd TFT LCD module using ESP32 module below is the code I have used:
<#include <Adafruit_GFX.h>    // include Adafruit graphics library
#include <Adafruit_ST7735.h> // include Adafruit ST7735 display library
#include <SPI.h>             // include Arduino SPI library
#include <SD.h>              // include Arduino SD library
// define ST7735 TFT display connections
#define TFT_RST  5   // reset line (optional, pass -1 if not used)
#define TFT_CS   6   // chip select line
#define TFT_DC   7   // data/command line
#define button   2  // button pin
// initialize Adafruit ST7735 TFT library
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
  pinMode(TFT_CS, OUTPUT);
  digitalWrite(TFT_CS, HIGH);
  pinMode(button, INPUT_PULLUP);
  // initialize ST7735S TFT display
  tft.initR(INITR_BLACKTAB);
  tft.fillScreen(ST77XX_BLUE);
  Serial.print("Initializing SD card...");
  if (!SD.begin()) {
    Serial.println("failed!");
    while(1);  // stay here
  Serial.println("OK!");
  File root = SD.open("/");  // open SD card main root
  printDirectory(root, 0);   // print all files names and sizes
  root.close();              // close the opened root
  while (true) {
    File entry =  root.openNextFile();  // open file
    if (! entry) {
      // no more files
      root.close();
      return;
    uint8_t nameSize = String(entry.name()).length();  // get file name size
    String str1 = String(entry.name()).substring( nameSize - 4 );  // save the last 4 characters (file extension)
    if ( str1.equalsIgnoreCase(".bmp") )  // if the file has '.bmp' extension
      bmpDraw(entry.name(), 0, 0);        // draw it
    entry.close();  // close the file
    while( digitalRead(button) ) ;  // wait for button press
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.startWrite();
        tft.setAddrWindow(x, y, w, h);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            tft.endWrite();
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
              tft.startWrite();
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.color565(r,g,b));
          } // end pixel
        } // end scanline
        tft.endWrite();
        Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
void printDirectory(File dir, int numTabs) {
  while (true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
    for (uint8_t i = 0; i < numTabs; i++) {
      Serial.print('\t');
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println("/");
      printDirectory(entry, numTabs + 1);
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.println(entry.size(), DEC);
    entry.close();
I'm getting errors is below
<D:\b1_training\vm_project_task\st7735_image_ardu\st7735_image_ardu\st7735_image_ardu.ino: In function 'void loop()': st7735_image_ardu:57:25: error: invalid conversion from 'const char*' to 'char*' [-fpermissive] bmpDraw(entry.name(), 0, 0); // draw it ^ D:\b1_training\vm_project_task\st7735_image_ardu\st7735_image_ardu\st7735_image_ardu.ino:76:6: note: initializing argument 1 of 'void bmpDraw(char*, uint8_t, uint16_t)' void bmpDraw(char *filename, uint8_t x, uint16_t y) { ^ Multiple libraries were found for "SD.h" Used: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\SD Not used: C:\Program Files (x86)\Arduino\libraries\SD exit status 1 invalid conversion from 'const char*' to 'char*' [-fpermissive]/>
please help me, how to fix this error
thank you for your time
Your post was MOVED to its current location as it is more suitable.
I can't test it but see if the below change will fix it
to
void bmpDraw(const char *filename, uint8_t x, uint16_t y) {
Thank you for your response, error was cleared after putting your solution in code but on lcd NO image displayed
in terminal something else is getting I have checked in code also there is no serial print is wrote like "Rebooting.." which as shown in terminal
Thank you for your time.
Aren’t you supposed to pass reference since File is inherited from Stream?
