Code error I checked everything and didn't understand where I was wrong
Code:
void setup () {
pinMode (12,OUTPUT);
void loop () {
digitalWrite (HIGH);
delay (1000);
digitalWrite (LOW);
delay (1000);
Error:
/sdk/hardware/arduino/cores/arduino/Arduino.h:102:6: note: declared here void digitalWrite(uint8_t pin, uint8_t value);
Return code is not 0
the code should flash a light bulb and I'm new to this business.
First I recommend you read:
" How to get the best out of this forum "
and enclose your code in </> tags.
You need to inform which pin you are commanding the digital write.
Here are the errors:
write:
digitalWrite(12, HIGH); instead of digitalWrite(HIGH);
and
digitalWrite(12, LOW); instead of digitalWrite ( LOW);
Help us help you.
Images of code suck.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Images of error messages suck.
Include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Post a schematic.
Post an image of your project.
Which Micro Controller are you using?
Is this simulator code?
Please describe the problem better then you just did.
Thank u its worked
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
