Code:
ledsOff();
digitalWrite(3,HIGH);
ledsOff();
digitalWrite(5,HIGH);
ledsOff();
digitalWrite(6,HIGH);
ledsOff();
digitalWrite(7,HIGH);
ledsOff();
digitalWrite(8,HIGH);
ledsOff();
digitalWrite(9,HIGH);
ledsOff();
digitalWrite(11,HIGH);
ledsOff();
digitalWrite(13,HIGH);
Error:
function 'void loop()': sketch_nov20a.ino:2:13: error: 'ledsOff' was not declared in this scope
the error is most likely in the lines ledsOff();
Your topic was MOVED to its current forum category which is more appropriate than the original as it is not an Introductory Tutorial
Use [color = red]code tags[/color] (the </> icon above the compose window) to make it easier to read and copy for examination
Please post your complete sketch, not just part of it
which is a call to a function which i do not see anywhere, nor do i see setup(), please post the complete code
here is the full code
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
I do everything by the book 77 arduino projects but there was no setup(); command.
gcjr
5
not only is "setup()" missing, but "ledsOff()" as well
not quite by the book
I redid the code but the same error
void setup(){
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(11,OUTPUT);
pinMode(13,OUTPUT);
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
ledsOff();
gcjr
7
still missing ledsOff()
do you understanding that "ledsOff()" is not some standard Arduino library function.
not sure why you need it. it looks like your code is simply turning on each LED in sequence every 1 sec.
try removing the lines with ledsOff() and see if program compiles and does what you expect
thank you very much, I'm a beginner and for me flashing LEDs is something incredible
b707
9
This does not mean that you can violate the rules of the forum. You posted code without tags three times
You must to read this before you proceed:-
how to get the best out of this forum
