Code error "no matching function for call to...."
I've got the following codes from the internet as my project. But the error occurs and I don't know how to solve it. Please help. Thank you.
#include "DHT.h"
#include<LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#define dht_dpin 12
DHT dht;
#define pwm 9
byte degree[8] =
0b00011,
0b00011,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000
lcd.begin(16, 2);
lcd.createChar(1, degree);
lcd.clear();
lcd.print(" Fan Speed ");
lcd.setCursor(0,1);
lcd.print(" Controlling ");
delay(2000);
analogWrite(pwm, 255);
lcd.clear();
lcd.print("Circuit Digest ");
delay(2000);
DHT.read11(dht_dpin);
int temp = DHT.temperature;
lcd.setCursor(0,0);
lcd.print("Temperature:");
lcd.print(temp); // Printing temperature on LCD
lcd.write(1);
lcd.print("C");
lcd.setCursor(0,1);
if(temp <26 )
analogWrite(9,0);
lcd.print("Fan OFF ");
delay(100);
else if(temp==26)
analogWrite(pwm, 51);
lcd.print("Fan Speed: 20% ");
delay(100);
else if(temp==27)
analogWrite(pwm, 102);
lcd.print("Fan Speed: 40% ");
delay(100);
else if(temp==28)
analogWrite(pwm, 153);
lcd.print("Fan Speed: 60% ");
delay(100);
else if(temp==29)
analogWrite(pwm, 204);
lcd.print("Fan Speed: 80% ");
delay(100);
else if(temp>29)
lcd.print("Fan Speed: 100% ");
delay(100);
delay(3000);
The error message says:
Arduino: 1.6.9 (Windows 8.1), Board: "Arduino/Genuino Uno"
sketch_sep06a:8: error: no matching function for call to 'DHT::DHT()'
DHT dht;
C:\Users\Something\Desktop\sketch_sep06a\sketch_sep06a.ino:8:5: note: candidates are:
In file included from C:\Users\Something\Desktop\sketch_sep06a\sketch_sep06a.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
DHT(uint8_t pin, uint8_t type, uint8_t count=6);
C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: candidate expects 3 arguments, 0 provided
C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
class DHT {
C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
C:\Users\Something\Desktop\sketch_sep06a\sketch_sep06a.ino: In function 'void loop()':
sketch_sep06a:38: error: expected unqualified-id before '.' token
sketch_sep06a:39: error: expected primary-expression before '.' token
exit status 1
option enabled in File -> Preferences.
It is best if you could refer to the example sketch that came with the library. You have incorrectly declared your DHT sensor, and the methods called are invalid.
DHT dht; //Change to code below
#define DHTTYPE DHT22
DHT dht(dht_dpin, DHTTYPE);
DHT.read11(dht_dpin); //Remove this
int temp = DHT.temperature; //This function returns a float, dht are small letters, change to code below
float temp = dht.readTemperature();
Thanks a lot. It works, but didn't try it with the circuit yet. Thanks again.
You have to read the error messages (and also use code tags!).
You provided 0 arguments to the constructor, which it is not designed to operate with.
Later on:
DHT is the class, not an instance of the class. Try:
dht.read11(dht_dpin);
It's like saying "I took dog for a walk" (well, some people might talk like that). You should say "I took Fido for a walk" where Fido is an instance of the class dog.
this is my code
#include "DHT.h"
#include <LiquidCrystal.h>
#define DHTPin 2
LiquidCrystal lcd(1, 3, 4, 5, 6, 7);
#define dht_dpin 12
   lcd.begin(16,2);
 float temp = dht.getTemperature();
 float humi =dht.getHumidity();
 lcd.setCursor(0,0);
 lcd.print("Temp: ");
 lcd.print(temp);
 lcd.print(" C");
 lcd.setCursor(0,1);
 lcd.print("Humi");
 lcd.print(humi);
 lcd.print(" %");
 delay(2000);
this error ocurs
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\a\Documents\Arduino\ajinkya\ajinkya.ino: In function 'void loop()':
ajinkya:17: error: 'class DHT' has no member named 'getTemperature'
ajinkya:18: error: 'class DHT' has no member named 'getHumidity'
exit status 1
So open up DHT.h and find out what the methods are.
But most importantly, don't hijack an old thread. Start your own.
