Code error
I am trying to write an Arduino code that can Rotate Camera Based on Sound sensor like the code showing , the problem that the stepper motor just Spain without stoping!!
int motorPin1 = 8; int motorPin2 = 10; int motorPin3 = 9; int motorPin4 = 11; int sound_sensor1 = A8; int sound_sensor2 = A9;
int delayTime = 20;
void setup() { pinMode(motorPin1, OUTPUT); pinMode(motorPin2, OUTPUT); pinMode(motorPin3, OUTPUT); pinMode(motorPin4, OUTPUT); pinMode(sound_sensor1, INPUT); pinMode(sound_sensor2, INPUT);
void loop() { int sensor1 = analogRead(sensor1); int sensor2 = analogRead(sensor2); if (sensor1 >sensor2); { digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); delay(delayTime); } if (sensor2 >sensor1); { digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH); delay(delayTime); } }
Try defining your pin variables with the word pin in it, like const byte  sound_sensor1_[color=Red][b]Pin[/b][/color] = A8; Instead of int sound_sensor1 = A8;
You'll see then that it makes writting analogRead() commands easier and more obvious to debug :)
(Hope the hint is big enough for you to find one of your bug)
Which Arduino board are you using ?
 if (status_sensor1 > status_sensor2);
Why are you comparing 2 variables that have not been declared ? Why is there a semicolon on the end of the comparison ?
sorry that after 1000 trying to fix the code :) the first one was declared all that the code now , iam using arduino mega
int motorPin1 = 8; int motorPin2 = 10; int motorPin3 = 9; int motorPin4 = 11; const byte sound_sensor1_Pin = A8; const byte sound_sensor2_Pin = A9;
int delayTime = 20;
void setup() { pinMode(motorPin1, OUTPUT); pinMode(motorPin2, OUTPUT); pinMode(motorPin3, OUTPUT); pinMode(motorPin4, OUTPUT); pinMode(sound_sensor1_Pin, INPUT); pinMode(sound_sensor2_Pin, INPUT);
void loop() { int sensor1 = analogRead(sound_sensor1_Pin); int sensor2 = analogRead(sound_sensor2_Pin); if (sensor1 >sensor2) { digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); delay(delayTime); } if (sensor2 >sensor1) { digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH); delay(delayTime); } }
J-M-L: Try defining your pin variables with the word pin in it, like const byte sound_sensor1_[color=Red][b]Pin[/b][/color] = A8; Instead of int sound_sensor1 = A8;
Yeah now if sound is there the led on uln2003 light but stepper motor, not moving
Try first playing with your motor and understand how they work
J-M-L: Try first playing with your motor and understand how they work
Ok thanks, man :), but there is any other way to comd stepper to move like if sound1==1 step=left ? I mean stepper motor has name on direction?
What motor do you have ? What are the 4 pins Connected to?
J-M-L: What motor do you have ? What are the 4 pins Connected to?
i have stepper motor 28byj in1=8 in2 =10 in3=9 in4= 11
With a ULN2003?
J-M-L: With a ULN2003?
yes with ULN2003A I tested stepper with code from Arduino web and work fine
