Code error
Hey. I would like help with my code,i have no idea where is error, error is "no matching function for call to 'HX711::HX711(int, int)'".
from "HX711 scale(5,6);"
full code: #include <Wire.h>
#include "HX711.h"
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
HX711 scale(5,6);
#define clk 2
#define dt 3
#define sw 4
#define in1 7
#define in2 8
#define in3 9
#define in4 10
#define in5 11
#define in6 12
volatile boolean TurnDetected;
volatile boolean up;
bool doonce = 0;
char screen = 0;
boolean changestate = 0;
long weight;
int pump1ml = 20;
int pump2ml = 20;
int pump3ml = 20;
void isr0 () {
TurnDetected = true;
up = (digitalRead(clk) == digitalRead(dt));
lcd.begin(16, 2);
pinMode(sw, INPUT_PULLUP);
pinMode(clk, INPUT);
pinMode(dt, INPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(in5, OUTPUT);
pinMode(in6, OUTPUT);
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
digitalWrite(in5, LOW);
digitalWrite(in6, LOW);
attachInterrupt (0, isr0, RISING);
if (TurnDetected) {
delay(200);
doonce = 0;
if (changestate == 0) {
if (up) {
screen++;
if (screen > 3) {
screen = 3;
else {
screen = screen - 1;
if (screen < 0) {
screen = 0;
else {
if (up) {
switch (screen) {
case 0: pump1ml = pump1ml + 10;
case 1: pump2ml = pump2ml + 10;
case 2: pump3ml = pump3ml + 10;
else {
switch (screen) {
case 0: pump1ml = pump1ml - 10;
case 1: pump2ml = pump2ml - 10;
case 2: pump3ml = pump3ml - 10;
TurnDetected = false;
if (digitalRead(sw) == LOW) {
delay(200);
changestate = !changestate;
doonce = 0;
if (screen == 0 && doonce == 0) {
lcd.clear();
lcd.print("Vodka");
lcd.setCursor(0, 1);
lcd.print(pump1ml);
lcd.setCursor(3, 1);
lcd.print("ml");
lcd.setCursor(9, 0 );
lcd.print("Change?");
doonce = 1;
if (screen == 1 && doonce == 0) {
lcd.clear();
lcd.print("Cranberry");
lcd.print(pump2ml);
lcd.print("ml");
doonce = 1;
if (screen == 2 && doonce == 0) {
lcd.clear();
lcd.print("Grpfruit");
lcd.print(pump3ml);
lcd.print("ml");
doonce = 1;
if (screen == 3 && doonce == 0) {
lcd.clear();
lcd.print("Start?");
doonce = 1;
else {
lcd.print("Wait!");
delay(2000);
weight = scale.read();
delay(100);
lcd.clear();
lcd.print("Pump 1 ON");
digitalWrite(in1, HIGH);
while (scale.read() - weight < 3000) {
lcd.clear();
lcd.print(pump1ml);
lcd.print("ml");
delay((pump1ml/11)*1000);
delay(2000);
delay(100);
lcd.clear();
lcd.print("Pump 2 ON");
digitalWrite(in3, HIGH);
lcd.clear();
lcd.print(pump2ml);
lcd.print("ml");
delay((pump2ml/12)*1000);
delay(2000);
delay(100);
lcd.clear();
lcd.print("Pump 3 ON");
digitalWrite(in5, HIGH);
lcd.clear();
lcd.print(pump3ml);
lcd.print("ml");
delay((pump3ml/12)*1000);
delay(2000);
changestate = 0;
Hi and welcome! Please have a look at "How to use the forum" and edit your post here before you make any more post. Especially that part about code tags. Also, that is NOT the complete error. That DOES contain more info :wink:
HX711 scale(5,6);
For the HX711 library at GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales., there is no constructor that takes any arguments. The pin numbers are specified in the begin() function. See the HX711_basic_example example. If that is not the library that you are using, give us a link to the right one.
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask a good question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
