Hello, everybody!
I'm starting in this Arduino world with a small project to control my air conditioning.
First I got the infrared signal and once I got the commands, I proceeded to write this code to control my air via MQTT, but I have a working problem and I needed some advice too.
The problem is that when I load my code, or when I reset the ESP8266 module or if there is a loss of connection, in any of those circumstances, the air turns on without me giving any command. It only happens the first time, then the operation is correct. Could someone tell me what's wrong with my code?
#include <Arduino.h>
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "San Blas";
const char* password = "seba2703";
const char* mqtt_server = "192.168.0.15";
const uint16_t kIrLed = 4;
IRsend irsend(kIrLed);
WiFiClient espClient;
PubSubClient client(espClient);
uint16_t TEMP17[199] = {4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 5298, 4269, 4497, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 654, 433, 654, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433, 1732, 433, 654, 433, 1732, 433, 1732, 433, 1732, 433};
///Delete a long part//
uint16_t Off[199] = {4269, 0xxxx, 0000};
uint16_t On[199] = {4269,00};
pinMode(BUILTIN_LED, OUTPUT);
// digitalWrite(BUILTIN_LED, HIGH);
irsend.begin();
//#if ESP8266
// Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
//#else // ESP8266
//Serial.begin(115200, SERIAL_8N1);
//#endif // ESP8266
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
void setup_wifi() {
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected - ESP IP address: ");
void callback(String topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
int i=0;
for (i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
if(topic=="esp1/habitacion/aire"){
Serial.print("Estado del aire: ");
if(messageTemp == "1"){
irsend.sendRaw(On, 199, 38);
Serial.print("Encendido");
client.publish("esp1/habitacion/aire/state","ON");
else if(messageTemp == "0"){
irsend.sendRaw(Off, 199, 38);
Serial.print("Apagado");
client.publish("esp1/habitacion/aire/state","OFF");
if(topic=="esp1/habitacion/aire/temperatura"){
Serial.print("Temperatura del aire: ");
if(messageTemp == "17"){
irsend.sendRaw(TEMP17, 199, 38);
Serial.print("17º C");
client.publish("esp1/habitacion/aire/temperatura/state","17");
else if(messageTemp == "18"){
irsend.sendRaw(TEMP18, 199, 38);
Serial.print("18º C");
client.publish("esp1/habitacion/aire/temperatura/state","18");
else if(messageTemp == "19"){
irsend.sendRaw(TEMP19, 199, 38);
Serial.print("19º C");
client.publish("esp1/habitacion/aire/temperatura/state","19");
else if(messageTemp == "20"){
irsend.sendRaw(TEMP20, 199, 38);
Serial.print("20º C");
client.publish("esp1/habitacion/aire/temperatura/state","20");
else if(messageTemp == "21"){
irsend.sendRaw(TEMP21, 199, 38);
Serial.print("21º C");
client.publish("esp1/habitacion/aire/temperatura/state","21");
else if(messageTemp == "22"){
irsend.sendRaw(TEMP22, 199, 38);
Serial.print("22º C");
client.publish("esp1/habitacion/aire/temperatura/state","22");
else if(messageTemp == "23"){
irsend.sendRaw(TEMP23, 199, 38);
Serial.print("23º C");
client.publish("esp1/habitacion/aire/temperatura/state","23");
else if(messageTemp == "24"){
irsend.sendRaw(TEMP24, 199, 38);
Serial.print("24º C");
client.publish("esp1/habitacion/aire/temperatura/state","24");
else if(messageTemp == "25"){
irsend.sendRaw(TEMP25, 199, 38);
Serial.print("25º C");
client.publish("esp1/habitacion/aire/temperatura/state","25");
else if(messageTemp == "26"){
irsend.sendRaw(TEMP26, 199, 38);
Serial.print("26º C");
client.publish("esp1/habitacion/aire/temperatura/state","26");
else if(messageTemp == "27"){
irsend.sendRaw(TEMP27, 199, 38);
Serial.print("27º C");
client.publish("esp1/habitacion/aire/temperatura/state","27");
else if(messageTemp == "28"){
irsend.sendRaw(TEMP28, 199, 38);
Serial.print("28º C");
client.publish("esp1/habitacion/aire/temperatura/state","28");
else if(messageTemp == "29"){
irsend.sendRaw(TEMP29, 199, 38);
Serial.print("29º C");
client.publish("esp1/habitacion/aire/temperatura/state","29");
else if(messageTemp == "30"){
irsend.sendRaw(TEMP30, 199, 38);
Serial.print("30º C");
client.publish("esp1/habitacion/aire/temperatura/state","30");
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect("ESP8266Client")) {
Serial.println("connected");
client.subscribe("esp1/habitacion/aire");
client.subscribe("esp1/habitacion/aire/temperatura");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
if (!client.connected()) {
reconnect();
if(!client.loop())
client.connect("ESP8266Client");
Second I wanted to ask your advice about the same code because the second part (where I control the temperature) I am seeing that it is a too long code and I think I could shrink it a bit, any recommendation?
Thank you very much!
