Code executing but not updating variable values
I know you guys are harsh to noobies who don't format their posts, pls be kind to me, I'll provide everything I can and I really appreciate the help!! :slight_smile:
I'm writing code for a clock, the clock aspect is fully functional I'm adding another 'mode' as a countdown however whenever I call 'getTime()' it executes as shown in the serial monitor, it's executing but doesn't update the values of the curtime I cannot understand why, in the serial you can see it's 20:53 when in the corner the actual time is 20:56. If I switch it back to the clock it works no worries.
also pls forgive the spaghetti code.
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
const unsigned char byte1[10] = {
  0x83, 0x80, 0x8B, 0x8A, 0x8A, 0x0A, 0x0B, 0x80, 0x8B, 0x8A
const unsigned char byte2[10] = {
  0xFF, 0xE1, 0xBF, 0xFF, 0xE5, 0xFF, 0xFF, 0xE7, 0xFF, 0xE7
byte tm_buffer[10] = {0x83, 0xED, 0x83, 0xFF, 0x0B, 0x3F, 0x8B, 0xED, 0x81, 0x0C};
//                   |  Grid 1  |   Grid 2  |   Grid 3  |   Grid 4  |   Grid 5  |
//byte tm_buffer[10] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x0C};
int tm_dio = 9;
int tm_clk = 8;
int tm_stb = 7;
tmElements_t tm;
//INPUT BUTTONS
int button1 = 10;
int button2 = 11;
  pinMode(13, OUTPUT);
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  initial(2);
  Serial.println("initialised");
  writeBuffer();
int curTime[4] = {0,0,0,0}; //0,1,2
int AP = 1;
int mode = 0;
int var = 0;
int count = 0;
int longPress = 0;
void loop() { // 100Hz, 10Hz, 1Hz
  if (mode == 0) { //clock
    updateTimeDisplay();
  if (mode == 1) { //timer
    Countdown();
  if (mode == 2) { //temp
  if (digitalRead(button1) == LOW && var == 0) {
    if (mode == 1 && digitalRead(button1) == LOW) {
      longPress++;
    if (mode != 1 || longPress == 30) { //Change this value to change how long to hold button for. 30*delay(50) gives ALSO MUST ALTER the value for confirming minutes in COUNTDOWN();
      changeMode();
      var = 1;
      longPress = 0;
  else if (digitalRead(button1) == HIGH) {
    var = 0;
    longPress = 0;
/*void put2digits(int number, int pos) {
  if (number >=0 && number < 10) {
    putDigitAt(number, pos);
    putDigitAt(0, pos+1);
int timertime[4] = {0,0,0,0};
int fintime[4] = {0,0,0,0};
int timerrunning = 0;
int minutes = 0;
int milliscompare[2] = {0,0};
int change = 0;
void Countdown() {
  if (timerrunning == 0) {
    if (digitalRead(button2) == LOW) {
      minutes++;
    clearBuffer();
    putDigitAt(minutes % 10,1);
    putDigitAt((minutes / 10) % 10,0);
    putDigitAt((minutes) / 100 % 10,2);
    writeBuffer();
    if (digitalRead(button1) == LOW) {
      milliscompare[0] = millis();
      change = 1;
    else if (digitalRead(button1) == HIGH && change == 1) {
      milliscompare[1] = millis();
      if (milliscompare[1] - milliscompare[0] < 30 * 50) {
        int overshot = 0;
        timerrunning = 1;
        timertime[3] = minutes % 10; //00:01
        timertime[2] = (minutes / 10) % 10; //00:10
        if (minutes > 59) {
          overshot = (minutes / 60);
          timertime[2] = ((minutes - (60 * overshot)) / 10) % 10; //00:10
          timertime[1] = overshot % 10; //01:00
          timertime[0] = (overshot / 10) % 10; //10:00
        if (RTC.read(tm)) {
          fintime[3] = (tm.Minute % 10) + timertime[3]; // 00:01
          fintime[2] = ((tm.Minute / 10) % 10) + timertime[2]; // 00:10
          fintime[1] = ((tm.Hour) % 10) + timertime[1]; // 01:00
          fintime[0] = (((tm.Hour) / 10) % 10) + timertime[0]; // 10:00
          if (fintime[3] > 9) {
            fintime[2]++;
            fintime[3] = fintime[3] - 10;
          if (fintime[2] > 5) {
            fintime[2] = fintime[2] - 6;
            fintime[1]++;
          if (fintime[1] > 9) {
            fintime[1] = fintime[1] - 10;
            fintime[0]++;
          if (fintime[0] > 1 && fintime[1] > 3) {
            fintime[0] = fintime[0] - 2;
            fintime[1] = fintime[1] - 4;
      change = 0;
  else if (timerrunning == 1) {
    getTime(24);
    Serial.print(curTime[3]);
    Serial.print(curTime[2]);
    Serial.print(curTime[0]);
    Serial.println(curTime[1]);
    putDigitAt(fintime[0] - curTime[3], 3); // 10:00
    putDigitAt(fintime[1] - curTime[2], 2); // 01:00
    putDigitAt(fintime[2] - curTime[0], 0); // 00:10
    putDigitAt(fintime[3] - curTime[1], 1); // 00:01
    writeBuffer();
    //for (int i = 0
  delay(50);
void changeMode() {
  if (mode < 1) {
      mode++;
  else{
    mode = 0;
  while (digitalRead(button1) == LOW) {
void getTime(int type) {
  Serial.println(type);
  if (type == 12) {
    if (tm.Hour > 12) {
      curTime[2] = (tm.Hour - 12) % 10;
      curTime[3] = ((tm.Hour - 12) / 10) % 10;
      AP = 1;
    else {
      curTime[2] = (tm.Hour) % 10;
      curTime[3] = ((tm.Hour) / 10) % 10;
      AP = 0;
    if (tm.Hour == 0) {
      curTime[2] = 2;
      curTime[3] = 1;
  if (type == 24) {
    Serial.println("WHY ARE YOU NOT EXECUTING THIS");
    curTime[2] = tm.Hour % 10;        // 01:00
    curTime[3] = (tm.Hour / 10) % 10; // 10:00
    AP = 3;
  curTime[1] = tm.Minute % 10;        // 00:01
  curTime[0] = (tm.Minute / 10) % 10; // 00:10
void updateTimeDisplay() {
  clearBuffer();
  if (RTC.read(tm)) {
    getTime(12);
    if (AP == 3) {
    else if (AP == 1 || tm.Hour == 12) {
      bitWrite(tm_buffer[9], 6, 1);
    else {
      bitWrite(tm_buffer[9], 5, 1);
    for (int i = 0; i < 4; i++) {
      if (i == 3 && curTime[3] == 0) {}
      else {
        putDigitAt(curTime[i], i);
    bitWrite(tm_buffer[4], 4, 1); //turn on centre dots
    writeBuffer();
void putDigitAt(int digit, int pos) {
  tm_buffer[pos*2] = byte1[digit];
  tm_buffer[(pos*2) + 1] = byte2[digit];
  if (digit <=9 && digit >=4 && digit !=7 || digit == 0){
    switch (pos){
      case 0:
        bitWrite(tm_buffer[8],7,1);
      case 1:
        bitWrite(tm_buffer[9],2,1);
      case 2:
        bitWrite(tm_buffer[9], 3, 1);
      case 3:
        bitWrite(tm_buffer[8], 0, 1);
  else {
    switch (pos) {
      case 0:
        bitWrite(tm_buffer[8],7,0);
      case 1:
        bitWrite(tm_buffer[9],2,0);
      case 2:
        bitWrite(tm_buffer[9], 3, 0);
      case 3:
        bitWrite(tm_buffer[8], 0, 0);
void initial(int intensity) {
  pinMode(tm_dio, OUTPUT);
  pinMode(tm_clk, OUTPUT);
  pinMode(tm_stb, OUTPUT);
  digitalWrite(tm_stb, HIGH);
  digitalWrite(tm_clk, HIGH);
  // delay(200);
  tm_sendCommand(0x40); // command 2
  digitalWrite(tm_stb, LOW);
  tm_sendByte(0xc0); // command 3
  for (int i = 0; i < 16; i++)
    tm_sendByte(0x00); // clear RAM
  tm_sendCommand(0x03); // command 1
  setIntensity(intensity);
void clearBuffer() {
  for (int i = 0; i < 10; i++) {
    tm_buffer[i] = 0x00;
void setIntensity(int intensity)
  if (intensity < 0)
      tm_sendCommand(0x80); // command 4
      return;
    tm_sendCommand(0x88 | (intensity % 8));
void writeBuffer() {
  for (int i = 0; i < 16; i++){
    tm_sendByte(tm_buffer[i]); // set RAM
void tm_sendCommand(byte data)
  tm_sendByte(data);
void tm_sendByte(byte data)
  for (int i = 0; i < 8; i++)
      digitalWrite(tm_clk, LOW);
      digitalWrite(tm_dio, data & 1 ? HIGH : LOW);
      data >>= 1;
void dp() {
  bitWrite(tm_buffer[0], 4, 1);
It does execute the code, the array gets updated but if in countdown mode the tm value doesn't get updated often enough.
Thanks for the reply!
You are right, thank you I overlooked that :slight_smile: sorry for my ignorance
