Hi guys,i need to create a program which allow my ip camera to send out a noise from the speaker, when it detect a motion more than 30sec. (contentious HIGH for more than 30 sec) This program is working ,but dont understand the program at all. can someone pls explain it to me in the simplest way.
int ledPin = 13;//Declare the led pin number
int PushButton = 2;//Declare the PushButton number
int SpeakerPin = 11;//Declare the speaker pin number
int freq = 16400;//The frequency output when HIGH
unsigned long alarmStart;
unsigned long timerStart;
int lastVal;
int alarmState;
pinMode(ledPin, OUTPUT);
pinMode(PushButton, INPUT);
pinMode(SpeakerPin, OUTPUT);
int Val = digitalRead(PushButton);
digitalWrite(ledPin, Val);
if (Val == HIGH)
if (lastVal == LOW)
timerStart = millis();
if (millis() - timerStart >= 30000UL) //30 seconds continuous sensor
if (!alarmState)
alarmStart = millis();
alarmState = 1;
alarmState = 0;
lastVal = Val;
soundAlarm();
void soundAlarm()
if (millis() - alarmStart <= 30000UL) // 30 seconds alarm time
tone(SpeakerPin, freq);// Speaker give out 16.4KHZ frequency
tone(SpeakerPin, 0);// Speaker give out 0 frequency
What is really needed here is a device that sends out an annoying noise when people cross-post the same question four or five times in a row. Something only audible to cross-posters.
Hi guys,i need to create a program which allow my ip camera to send out a noise from the speaker, when it detect a motion more than 30sec. (contentious HIGH for more than 30 sec) This program is working ,but dont understand the program at all. can someone pls correct the way i am explain the program in a simpler way. The program is working, just needing help explaining it, as my english is not good
unsigned long alarmStart;//Alarm start counting
unsigned long timerStart;//Timer start counting
int lastVal;//Remembering the previous reading from the inputpin state
int alarmState;//The current state of the output pin
pinMode(ledPin, OUTPUT);//Set ledPin as output
pinMode(PushButton, INPUT);//Set pushButton as input
pinMode(SpeakerPin, OUTPUT);//Set Speakerpin as output
delay(30000);//give the processor time to start up
int Val = digitalRead(PushButton);//Read PushButton state
digitalWrite(ledPin, Val);//LedPin turn on and off according to HIGH or LOW input
if (Val == HIGH)//If Val read pushButton as HIGH state
if (lastVal == LOW)if
timerStart = millis();//if Val become low timer start counting
if (millis() - timerStart >= 30000) //if the Val state is at there for longer than 30 seconds,it take it as actual current state
if (Val != alarmState)//Check to see if the Val state has changed,due to motion detectection
alarmStart = millis();//Start counting When Val equal to HIGH
alarmState = 1;//HIGH
alarmState = 0;//LOW
lastVal = Val;//lastVal equal to the Val input state
soundAlarm();//Speaker output
void soundAlarm() //Speaker function declaration
if (millis() - alarmStart <= 30000) // 30 seconds alarm time duration
digitalWrite(ledPin, Val);//LedPin turn on and off according to the button's state
if (Val == HIGH)//If the button is pressed (HIGH), go into this IF statement
if (lastVal == LOW) // if the buttons last state was low, indicating it was released, go into this IF statement
// this is the result of Val being HIGH and lastVal being LOW
timerStart = millis(); // start the timer
if (millis() - timerStart >= 30000) //if 30 seconds or more has past, go into this IF statement
if (Val != alarmState)//If the button is HIGH and the alarm state is LOW (Motion detected), go into this IF statement
alarmState = 1;// Set alarm state to HIGH
else // button was not pressed
alarmState = 0;//set alarm to LOW
if (millis() - alarmStart <= 30000) // play tone for 30 seconds
