Hello
I was wondering if anyone had any advice they might be willing to give me about my Trinket sketch as i'm baffled.
I am using a 5V Trinket from Adafruit and utilizing the PWM ability to cross fade 3 LEDs. When my input pin (GPIO #2) goes HIGH, the cross fade begins, and when it goes low, I want all 3 LEDs to turn off. However, after the cycle starts, if the input pin goes LOW, instead of actually turning the LEDs all completely off like i would like, they get "stuck" with either 1 or 2 of them still on (depending on where in the cross fade they are). Any help would be appreciated greatly, as i am still very new to programing arduinos and have been at this for many hours. Thank you in advance.
//****REMEMBER TO RENAME INT & PARAMETER NAMES*****
// Output
int outLed = 4; // NAME COLOR LED LATER
int greenPin = 0; // NAME COLOR LED LATER
int bluePin = 1; // NAME COLOR LED LATER
//Input
int inputPin = 2; //Input Actuator from Wave Shield
// Program variables ***RENAME BEFORE FINAL***
int redVal = 255; // Variables to store the values to send to the pins
int greenVal = 1; // Initial values are Red full, Green and Blue off
int blueVal = 1;
int i = 0; // Loop counter
int wait = 50; // 50ms (.05 second) delay; shorten for faster fades
//***REMAN BEFORE FINAL***
PWM4_init();
pinMode(outLed, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(inputPin, INPUT);
// Main program
void loop(){
int val = digitalRead(inputPin);
if (val == HIGH) //Turns Trinket on if GPIO#2 is HIGH
crossfade();
else { //Turns Trinket off if GPIO#2 is LOW
redVal = 1;
greenVal = 1;
blueVal = 1;
//CROSSFADE ROUTINE
void crossfade() {
i += 1; // Increment counter
if (i < 255) // First phase of fades
redVal -= 1; // Red down
greenVal += 1; // Green up
blueVal = 1; // Blue low
else if (i < 509) // Second phase of fades
redVal = 1; // Red low
greenVal -= 1; // Green down
blueVal += 1; // Blue up
else if (i < 763) // Third phase of fades
redVal += 1; // Red up
greenVal = 1; // Green low
blueVal -= 1; // Blue down
else // Re-set the counter, and start the fades again
i = 1;
analogWrite4(redVal); // Write current values to LED pins
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
delay(2); // ***THIS IS USED TO ADJUST SPEED OF INDIVIDUAL LED FADES***
//NECESSARY TO MAKE GPIO#4 WORK W/ PWM
void PWM4_init() {
// Set up PWM on Trinket GPIO #4 (PB4, pin 3) using Timer 1
TCCR1 = _BV (CS10); // no prescaler
GTCCR = _BV (COM1B1) | _BV (PWM1B); // clear OC1B on compare
OCR1B = 0; // duty cycle initialize to 50%
OCR1C = 255; // frequency
// Function to allow analogWrite on Trinket GPIO #4
void analogWrite4(uint8_t duty_value) {
OCR1B = duty_value; // duty may be 0 to 255 (0 to 100%)
