Code for arduino run on timer help beginner thanks
This is my code and I,m trying to put in a run on timer…, when my digital write 4 comes on it will go off when its greater than 2.5v and my program continues on…but I,m trying to put in the timer if it doesn,t hit that threshold 2.5v in 5 mins it will shut my digital write 4 off and another digital write 6 off
if (analogValue < threshold2){ //less 2volts digitalWrite(4,HIGH) ; //compressor on
} if (analogValue > threshold3){ //greater than 2.5 volts digitalWrite(4,LOW) ; // compressor off
Please post all your code and don't forget to put it inside code tags.
const int analogPin = A1; // Analog input pin that the potentiometer is attached to
const int threshold1 = 51 ; // 0.25 Volt value
const int threshold2 = 410 ; // 2 Volt value
const int threshold3 = 512 ; // 2.5 Volt value
const int threshold4 = 615 ; // 3 Volt value
const int threshold5 = 972 ; //4.75 volt value
pinMode(4, OUTPUT) ; // compressor led light
pinMode(6, OUTPUT) ; // Exhaust Valve light
Serial.begin(9600); // initialize serial communications at 9600 bps:
int analogValue = analogRead(analogPin);
if
(analogValue > threshold5){ // if analog value greater than 4.75v
digitalWrite(4,LOW); // turn off compressor
digitalWrite(6,LOW); // turn off exhaust valve
delay(60000); // resets after 60 seconds
if
(analogValue < threshold1){ //if analog value less than 0.25v
digitalWrite(4,LOW); //turn off compressor
digitalWrite(6,LOW); //turn off exhaust valve
delay(60000) ; // reset after 60 seconds
if
if
if
(analogValue > threshold4) { //greater than 3volts
digitalWrite(6,HIGH) ; //exhaust valve on
if
(analogValue < threshold3) //less than 2.5volts
digitalWrite(6,LOW) ; //exhaust valve off
Serial.println(analogValue) ;
delay(1) ;
Oopsie
❝and don't forget to put it inside code tags.
Sorry what is this i,m new to this ,what do you mean by inside code tags?
Please read the thread "How to use this forum - please read." near the top of the forum.
Code should
look like this
Use the code button. It looks like a scroll with <> on top.
…R
You have a lot of problems in here:
 if
 if
   digitalWrite(6,LOW);            //turn off compressor
   delay(60000) ;                       // reset after 10 seconds
The delays are the same, 60000, but the comments say otherwise.
In the second part, you comment that you’re turning off the compressor, but you actually turn off the valve.
Did you really mean to turn everything off (LOW)?
You used const int to give meaningful variable names to the analog pin. Please do it for the output pins too, so you and other readers don’t get confused.
Is the analog input connected to a pressure sensor? How about calling your analogValue variable “pressure” to make the comparison statements read more meaningfully? How about using the auto format feature in the IDE to improve the formatting of your statement blocks?
