code for beermachine
this is code for a beermachine :slight_smile:
#include <Servo.h>
#include <LiquidCrystal.h>
Servo myservo;
Servo secondserv0;// create servo object to control a servo
// a maximum of eight servo objects can be created
int pos =0; // variable to store the servo position
const int buttonPin = 7;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int buttonState = 0;
secondserv0.attach(1);
myservo.attach(0); // attaches the servo on pin 0 to the servo object
secondserv0.write(180);
myservo.write(90);
pinMode(buttonPin, INPUT);
lcd.begin(16, 2);
lcd.print("Beer Machine");
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH){
lcd.clear();
lcd.print("Pouring beer...");
for(pos = 90; pos >= 45; pos -= 1) // goes from 90 to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos >= 90; pos -= 1) // goes from 90 to 180 degrees
{ // in steps of 1 degree.
// 90 degrees is stopped.
secondserv0.write(pos); // rotate servo at speed given by 'angle'
delay(100); // waits 20ms between servo commands
delay(2000);
for(pos = 90; pos < 180; pos += 1)// goes from 180 to 90 degrees
secondserv0.write(pos); // rotate at a speed given by 'angle'
for(pos = 45; pos < 90; pos += 1)// goes from 180 to 90 degrees
delay(300); // waits 15ms for the servo to reach the position
}else {
Start here
Really?
Does the machine make beer?
There are so many places in that code where the comments don't match the code that it is almost as if the comments were from a different program.
Also
else what ?
      delay(2000);
Why the braces ?
Are these real servos or continuous rotation servos ? The code says one thing, the comments another.
As a matter of interest do you have a pulldown resistor in your button circuit or is the machine likely to dispense beer at random due to picking up noise ?
UKHeliBob:
Mmmm... random beer service. I can live with that.
