Good day guys,
Project overview - I am building a generator control board to start and stop the engine.
Going to install a speed sensor on flywheel to determine engine RPM.
I have googled but can only find examples using a standard delay function.
But I do not want to use a standard time for cranking the engine as the time that the engine could take to start differs due to environmental factors - cold etc.
What I want to do is for the starter to keep on cranking until the engine reaches a certain speed - (speed threshold is to indicate that the engine has started), in the event of a no start condition there must be a time out for the starter.
So engine cranks until certain speed is reached (starter kicks out) or if engine doesn't start starter kicks out after say 30 sec.
Does any one have some suggestions on how the code will look like for above?
Thanks in advance
