I am working on a project and would like some help. I am looking for Arduino uno code to generate a 40 KHZ pulse for 8 cycles and delay of 50 ms to drive my ultrasonic transmitter. At the moment I am only using the function generator in labs to achieve this.
So that would be 8 cycles on and 2000 cycles off would it?
This code pulses pin 3 for 8 cycles before turning it off.
/* Code to pulse pin 3 with a modulated signal
* Can be used to drive an IR LED to keep a TSOP IR reciever happy
* This allows you to use a modulated reciever and a continious beam detector
* By Mike Cook Nov 2011 - Released under the Open Source licence
volatile byte pulse = 0;
ISR(TIMER2_COMPB_vect){ // Interrupt service routine to pulse the modulated pin 3
pulse++;
if(pulse >= 8) { // change number for number of modulation cycles in a pulse
pulse =0;
TCCR2A ^= _BV(COM2B1); // toggle pin 3 enable, turning the pin on and off
void setIrModOutput(){ // sets pin 3 going at the IR modulation rate
pinMode(3, OUTPUT);
TCCR2A = _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); // Just enable output on Pin 3 and disable it on Pin 11
TCCR2B = _BV(WGM22) | _BV(CS22);
OCR2A = 51; // defines the frequency 51 = 38.4 KHz, 54 = 36.2 KHz, 58 = 34 KHz, 62 = 32 KHz
OCR2B = 26; // deines the duty cycle - Half the OCR2A value for 50%
TCCR2B = TCCR2B & 0b00111000 | 0x2; // select a prescale value of 8:1 of the system clock
void setup(){
setIrModOutput();
TIMSK2 = _BV(OCIE2B); // Output Compare Match B Interrupt Enable
void loop(){
// do something here
I think it is simple enough to modify this to carry on counting another 2000 cycles before turning it back on again.
Both the prescaler and the compare value affect the frequency. Typically the prescaler is used for raw timing, the OCR for fine tuning the frequency. The difference becomes more obvious with the duty cycle, that can range from 0 (0%) to OCR2A (100%).
