good evening to the arduino community, please please help
I try to upload my code, but I keep getting smacked with this error message. Using an Arduino Nano, Atmega328P (old bootloader). I was able to upload before on the same Nano, I don't know why it won't work now.
Sketch uses 7048 bytes (22%) of program storage space. Maximum is 30720 bytes.
Global variables use 638 bytes (31%) of dynamic memory, leaving 1410 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa0
Failed uploading: uploading error: exit status 1
I've tried reinstalling the IDE, tried updating its CH340 driver (but then already having the most up-to-date one), and tried the Nano's USB to different COM ports of my laptop. No avail to all my attempts.
im sorry if my upload format is wrong, this is my first time
P.S. I would like to upload my code too and explain my project (a mechanized greenhouse), but i'll start with this so it won't be messy, as my code is lengthy. T_T
#include <Wire.h>
#include <RTClib.h>
// Pin Definitions
#define RELAY_FAN_PIN 3 // Relay for fan
#define RELAY_WATER_PIN 4 // Relay for water pump
#define RELAY_LIGHT_PIN 5 // Relay for grow light
#define THERMOSTAT_PIN 7 // Pin connected to S1 of the thermostat
// Initialize RTC
RTC_DS3231 rtc;
// Threshold Values
const int LIGHT_ON_HOUR = 8; // Time to turn grow light ON
const int LIGHT_OFF_HOUR = 20; // Time to turn grow light OFF
const int WATER_INTERVAL_HOURS = 6; // Time between watering cycles
// Variables
DateTime lastWatering;
// Initialize Serial Monitor for debugging
// Initialize RTC
if (!rtc.begin()) {
Serial.println("RTC not found!");
while (1); // Halt execution if RTC is missing
if (rtc.lostPower()) {
Serial.println("RTC lost power, setting default time to 2025-01-01 00:00:00.");
rtc.adjust(DateTime(2025, 1, 1, 0, 0, 0)); // Set default time
// Set Relay Pins as Output
pinMode(RELAY_FAN_PIN, OUTPUT);
pinMode(RELAY_WATER_PIN, OUTPUT);
pinMode(RELAY_LIGHT_PIN, OUTPUT);
pinMode(THERMOSTAT_PIN, INPUT); // Input from thermostat
// Turn off all relays at the start
digitalWrite(RELAY_FAN_PIN, HIGH);
digitalWrite(RELAY_WATER_PIN, HIGH);
digitalWrite(RELAY_LIGHT_PIN, HIGH);
// Initialize last watering time
lastWatering = rtc.now();
delay(2000); // Wait 2 seconds to finish initialization
// Get current time
DateTime now = rtc.now();
// Debug Output to Serial Monitor
Serial.print("Current Time: ");
Serial.print(now.hour());
Serial.print(":");
Serial.println(now.minute());
// Control Fan (based on thermostat relay state)
int thermostatState = digitalRead(THERMOSTAT_PIN); // Check thermostat relay state
if (thermostatState == HIGH) { // Thermostat relay ON
digitalWrite(RELAY_FAN_PIN, LOW); // Turn ON fan
Serial.println("Fan ON - Thermostat triggered");
} else { // Thermostat relay OFF
digitalWrite(RELAY_FAN_PIN, HIGH); // Turn OFF fan
Serial.println("Fan OFF - Thermostat not triggered");
// Control Grow Light (based on time)
if (now.hour() >= LIGHT_ON_HOUR && now.hour() < LIGHT_OFF_HOUR) {
digitalWrite(RELAY_LIGHT_PIN, LOW); // Turn ON grow light
Serial.println("Grow Light ON");
digitalWrite(RELAY_LIGHT_PIN, HIGH); // Turn OFF grow light
Serial.println("Grow Light OFF");
// Control Water Pump (based on schedule)
if ((now - lastWatering).totalseconds() >= WATER_INTERVAL_HOURS * 3600) {
digitalWrite(RELAY_WATER_PIN, LOW); // Turn ON water pump
Serial.println("Water pump ON");
delay(7000); // Keep the pump ON for 7 seconds (adjust as needed)
digitalWrite(RELAY_WATER_PIN, HIGH); // Turn OFF water pump
Serial.println("Water pump OFF");
// Update last watering time
lastWatering = now;
delay(2000); // Wait 2 seconds before next loop
and I have the library RTClib by adafruit installed for the DS3231. Only that library verifies without error so that's my only library installed.
Okay, I updated the CH340 driver to the 2014 one. Tried to upload after but this error occurred still
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x79
2014 is really old - I thought I was linking to a thread that would give you a driver from 2020-2022, which I've done and found to be working successfully.
Okay. This is the thread I meant to link to:Rollback
Given the error message you're quoting, though, it sounds more like a comms error. You're not perchance connecting anything to pins 0 and 1? Please show us your code.
Nothing is currently connected to my Nano, other than the USB to my computer. I have a lot of defined pins but I removed them from the Nano for the sake of uploading. Here is my code.
#include <Wire.h>
#include <RTClib.h>
// Pin Definitions
// Initialize RTC
RTC_DS3231 rtc;
// Threshold Values
// Variables
// Initialize RTC
if (!rtc.begin()) {
// Get current time
Serial.print(":");
lastWatering = now;
I'll try the driver, however in the past it uploaded successfully without having to update its CH340... Also, serial monitor is blank despite how the previously uploaded code on it is supposed to atleast display a debug message (ex. "RTC not found!") .
the Nano was unresponsive when I pushed the reset button, multiple tries and times.
Moreover, the serial monitor is blank despite the board having an uploaded sketch stored in its memory supposedly. could this be a fault in the board’s hardware itself now?
(also rolled back the driver but I got the same error message)
