Code for LED vu-meter
First i will introduce myself! I am currently studying avionics in montreal, i know the basics but still have a lot to learn. My main trouble will be the programing, but i think i am coming along well :slight_smile:
One of my first projects is a vu-meter. i got it working, but i would like to smooth out the edges.
I would like to calculate a average over a certain amout of time (a few ms) and then process it to make the leds light up.
Here is the code i have for the moment:
int val = 0;
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
void loop(){
val = analogRead(0);
if(analogRead(2) > val){
digitalWrite(13, HIGH);
} else{
digitalWrite(13, LOW);
delay(10);
if(analogRead(2) > val+10){
digitalWrite(12, HIGH);
} else{
digitalWrite(12, LOW);
delay(10);
if(analogRead(2) > val+30){
digitalWrite(11, HIGH);
} else{
digitalWrite(11, LOW);
delay(10);
if(analogRead(2) > val+55){
digitalWrite(10, HIGH);
} else{
digitalWrite(10, LOW);
delay(10);
if(analogRead(2) > val+80){
digitalWrite(9, HIGH);
} else{
digitalWrite(9, LOW);
delay(10);
if(analogRead(2) > val+100){
digitalWrite(8, HIGH);
} else{
digitalWrite(8, LOW);
delay(10);
Thanks in advance for you help!
I started to tweak your code and ended up with this snippet:
[PSEUDOTESTED CODE] (seems to be working with potentiometers and serial console as output)
|| A simple VU meter using arduino with analog input smoothing
|| Contributed:
|| Alexander Brevig
//defines
#define NUMBER_OF_LEDS 6
#define NUMBER_OF_SAMPLES 20
#define DEBUG true
#define VU_METER_DISPLAY_DELAY 10
//analog in pins
byte voltageReferencePin = 0;
byte voltagePin = 2;
//digital out pins
//store the leds in an array, this way changing them later wont be a hazzle
byte ledPins[NUMBER_OF_LEDS] = { 8 , 9 , 10 , 11 , 12 , 13 };
//convert analogRead to VU ledscale
byte voltageComparisonThresholds[] = { 0 , 10 , 30 , 55 , 80 , 100 };
int voltageReference = 0; //contain analogRead(voltageReferencePin);
//sample variables
int samples[NUMBER_OF_SAMPLES] = {0};
int sample = 0;
int sampleTotal = 0;
byte sampleIndex = 0;
for (byte i=0; i<NUMBER_OF_LEDS; i++){
pinMode(ledPins*,OUTPUT);*
  • pinMode(voltageReferencePin,INPUT);*
  • pinMode(voltagePin,INPUT);*
  • if(DEBUG){Serial.begin(9600);}*
    void loop(){
  • //SMOOTH See Examples->Analog->Smoothing*
  • sampleTotal -= samples[sampleIndex];*
  • samples[sampleIndex] = analogRead(voltageReferencePin);//read value*
  • sampleTotal += samples[sampleIndex++]; *
  • if (sampleIndex >= NUMBER_OF_SAMPLES) {sampleIndex = 0;}*
  • sample = sampleTotal / NUMBER_OF_SAMPLES;*
  • if(DEBUG){Serial.print("virtual vu: ");}*
  • //DISPLAY_RESULT*
  • //see Examples->Digital->Loop*
  • for (byte i=0; i<NUMBER_OF_LEDS; i++){*
    _ if ( analogRead(voltagePin) >= voltageReference + voltageComparisonThresholds ) {_
    _ digitalWrite(ledPins*,HIGH); if(DEBUG){Serial.print("|");}
    }else{
    digitalWrite(ledPins,LOW); if(DEBUG){Serial.print(" ");}
    }_
    delay(VU_METER_DISPLAY_DELAY);
    _ }
    if(DEBUG){ Serial.println(" "); }*_
}[/quote]
I almost feel guilty, steling all the coding fun. :expressionless:
[I will test when I have the chance.]
Wow i wasn't expecting such a detailed answer! It's very nice of you but it dosent seem to work, all the leds stay on at all times. I tried to see where the problem was, but i barely understand that kind of code.
Maybe just a way to make a average (over a few ms) of analogread(2) ?
Hello!
For analog smoothing see: Smoothing
About the code; it seem to function here, using the serial console, I get a nice bar. But! Beware that the thresholds are wery low, and you'll get a very limited reponse per voltage difference.
Try changing:
to
byte voltageComparisonThresholds[] = { 0 , 100 , 300 , 550 , 800 , 1000 };
If you think the code looks complex, you should take a look at Loop. They make things loog a bit wierd, but makes code much more compact. Eventually you'll see that it actually i simple:)
OK i got it working quite nicely now! I simply copy/pasted the smoothing technique, But i sticked to my longer version of the code because i understand it better.
Next step will be to vary the steps between each led proportionaly with a potentiometer, instead of simply rising/lowering the reference.
Here is the code:
int val = 0;
#define NUMREADINGS 10
int readings[NUMREADINGS];
int index = 0;
int total = 0;
int average = 0;
for (int i = 0; i < NUMREADINGS; i++)
readings *= 0; *
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
void loop(){
*total -= readings[index]; *
readings[index] = analogRead(2);
*total += readings[index]; *
*index = (index + 1); *
*if (index >= NUMREADINGS) *
*index = 0; *
*average = total / NUMREADINGS; *
if(average > val){
} else{
if(average > val+10){
} else{
if(average > val+30){
} else{
if(average > val+55){
} else{
if(average > val+80){
} else{
if(average > val+100){
} else{
Sorry it is so long, im sticking to the easy way :slight_smile:
Nothing to say you're sorry for :slight_smile:
Glad you got it working!
