Oh right, sorry ill change it once i’ve finished. This is the bmp180 library im using as a reference point.
#include <SFE_BMP180.h>
#include <Wire.h>
// You will need to create an SFE_BMP180 object, here called "pressure":
SFE_BMP180 pressure;
#define ALTITUDE 1655.0 // Altitude of SparkFun's HQ in Boulder, CO. in meters
Serial.println("REBOOT");
// Initialize the sensor (it is important to get calibration values stored on the device).
if (pressure.begin())
Serial.println("BMP180 init success");
// Oops, something went wrong, this is usually a connection problem,
// see the comments at the top of this sketch for the proper connections.
Serial.println("BMP180 init fail\n\n");
while(1); // Pause forever.
char status;
double T,P,p0,a;
// Loop here getting pressure readings every 10 seconds.
// If you want sea-level-compensated pressure, as used in weather reports,
// you will need to know the altitude at which your measurements are taken.
// We're using a constant called ALTITUDE in this sketch:
Serial.print("provided altitude: ");
Serial.print(ALTITUDE,0);
Serial.print(" meters, ");
Serial.print(ALTITUDE*3.28084,0);
Serial.println(" feet");
// If you want to measure altitude, and not pressure, you will instead need
// to provide a known baseline pressure. This is shown at the end of the sketch.
// You must first get a temperature measurement to perform a pressure reading.
// Start a temperature measurement:
// If request is successful, the number of ms to wait is returned.
// If request is unsuccessful, 0 is returned.
status = pressure.startTemperature();
if (status != 0)
// Wait for the measurement to complete:
delay(status);
// Retrieve the completed temperature measurement:
// Note that the measurement is stored in the variable T.
// Function returns 1 if successful, 0 if failure.
status = pressure.getTemperature(T);
if (status != 0)
// Print out the measurement:
Serial.print("temperature: ");
Serial.print(T,2);
Serial.print(" deg C, ");
Serial.print((9.0/5.0)*T+32.0,2);
Serial.println(" deg F");
// Start a pressure measurement:
// The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
status = pressure.startPressure(3);
if (status != 0)
delay(status);
// Retrieve the completed pressure measurement:
// Note that the measurement is stored in the variable P.
// Note also that the function requires the previous temperature measurement (T).
// (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
status = pressure.getPressure(P,T);
if (status != 0)
Serial.print("absolute pressure: ");
Serial.print(P,2);
Serial.print(" mb, ");
Serial.print(P*0.0295333727,2);
Serial.println(" inHg");
// The pressure sensor returns abolute pressure, which varies with altitude.
// To remove the effects of altitude, use the sealevel function and your current altitude.
// This number is commonly used in weather reports.
// Parameters: P = absolute pressure in mb, ALTITUDE = current altitude in m.
// Result: p0 = sea-level compensated pressure in mb
p0 = pressure.sealevel(P,ALTITUDE); // we're at 1655 meters (Boulder, CO)
Serial.print("relative (sea-level) pressure: ");
Serial.print(p0,2);
Serial.print(p0*0.0295333727,2);
// On the other hand, if you want to determine your altitude from the pressure reading,
// use the altitude function along with a baseline pressure (sea-level or other).
// Parameters: P = absolute pressure in mb, p0 = baseline pressure in mb.
// Result: a = altitude in m.
a = pressure.altitude(P,p0);
Serial.print("computed altitude: ");
Serial.print(a,0);
Serial.print(a*3.28084,0);
else Serial.println("error retrieving pressure measurement\n");
else Serial.println("error starting pressure measurement\n");
else Serial.println("error retrieving temperature measurement\n");
else Serial.println("error starting temperature measurement\n");
delay(5000); // Pause for 5 seconds.
I’ve read it and re read it over and over again but not sure
this is what ive got so far.
#include <Wire.h>
#include <DHT11.h>
int pin = 2;
DHT11 dht11(pin);
LiquidCrystal_I2C lcd(0x27, 20, 4);
SFE_BMP180 Pressure;
#define Altitude 72.0 // Altitude of Central Sussex College
(Pressure.begin());
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Temp:");
lcd.setCursor(0, 2);
lcd.print("Pressure:");
lcd.setCursor(0, 1);
lcd.print("Humidity:");
lcd.setCursor(0, 3);
lcd.print("Altitude:");
int err;
float temp, humi;
dht11.read (humi, temp);
char status;
double T, P, p0, a;
lcd.clear();
delay(50);
lcd.setCursor(1, 1);
lcd.print("Temperature:");
lcd.print(temp);
lcd.print(" C");
lcd.setCursor(9, 0);
lcd.print(humi);
lcd.print(" %");
status = Pressure.startTemperature();
status = Pressure.getTemperature(T);
status = Pressure.startPressure(3);
status = Pressure.getPressure(P, T);
p0 = Pressure.sealevel(P, Altitude);
lcd.print(p0, 2);
lcd.print(" mb");
a = Pressure.altitude(P, p0);
lcd.println();
lcd.print(a * 3.28084, 0);
lcd.print(" ft");
// This is because im telling it what the altitude is at my location
delay(5000);
