i know some code of proximity but i dont know anything about servo code help me insert servo code inside this if value is 1 rotate 90degree right whereas if value is 1 rotate left 90degrees i want something like this pls help
int limitSwitch = 13;
int state = LOW;
pinMode(limitSwitch,INPUT);
int val = digitalRead(limitSwitch);
NINZJAZZ:
So just to check, you want it to go to two different places with the same input?
Or should one of those be "0"?
First, let's discuss your switch. Do you have a pull down resistor on it? (Asking since you have it pinMode()-ed as INPUT, so it would be wired from pin to 5V?) If not, rather change that to INPUT_PULLUP and wire the switch from pin to ground. Then when switch is open,pin is high; when it is closed, pin goes low.
Willpatel_Kendmirez:
yeah u are right 1 of them should be 0 that is my typo sorry i have 2 1* k resistor in proximity sensor circuit it is working it would be wired to 5v by breadboard if u can suggest some good ideas to connect explain to me please
and those servo examples i digested only potentiometer one second one got over my head
sorry for my bad english
pls tell me additional parts and tell me how to put it together i did the servo and ultrasonic but inductive sensor would take resistor as i heard pls tell how should put them
Duplicate posts waste the time of the people helping you. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread. This behavior is not very respectful to the people you're asking for assistance. Just because they give their time freely doesn't mean it has no value.
In the future, take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
#include <Servo.h> //add '<' and '>' before and after servo.h
float metalDetected;
int proximitySensorValue;
int proximitySensorPin = A1;
int servoPin = 4;
int servoAngle = 0; // servo position in degrees
Servo servo;
const int trigPin = 2;
const int echoPin = 3;
long duration;
int distance;
servo.attach(servoPin);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
proximitySensorValue = analogRead(proximitySensorPin);
metalDetected = (float) proximitySensorValue*100/1024.0;
Serial.print("Object detected: ");
Serial.print(metalDetected);
Serial.println("%");
it should detect metal with the inductive sensor however this is the out put in the serial monitor
in a constant loop even when the sensor is not close to a metal i want it to just tell me that metal is detected or not if metal is detected show 1 if not send 0 simple as that i have atached the pin to analog and connected the inductive sensor with a separate power supply 9v for whereas arduino is supplied with the usb and motor is by 5v
please help
const byte ProximitySensorPin = A1;
const byte TrigPin = 2;
const byte EchoPin = 3;
const byte ServoPin = 4;
byte servoAngle = 0; // servo position in degrees
Servo servo;
long duration;
int distance;
pinMode(TrigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(EchoPin, INPUT); // Sets the echoPin as an Input
pinMode(ProximitySensorPin, INPUT_PULLUP);
if(!digitalRead(ProximitySensorPin)){
Serial.print("Object detected!");
