I'm about to order a small motor and components to build a H-bridge.
I have written the following code and compiling gives no trouble.
Will this work?
I mean to control both directions with one potentiometer so the mapping is very important in this sketch. The value in the first mapping is inverted, will this work?
int potpin1 = A1; // analog pin used to read the potentiometer voltage
int PWMPin1 = 1; // PWM signal to digital pin 1
int PWMPin2 = 2; // PWM signal to digital pin 2
int value1;
int value2;
// nothing happens in setup
if (analogRead(potpin1) < 512)
value1 = map(potpin1, 0, 511, 255, 0);
analogWrite (PWMPin1, value1);
else if (analogRead(potpin1) > 524)
value2 = map(potpin1, 525, 1023, 0, 255);
analogWrite (PWMPin2, value2);
analogWrite (PWMPin1, 0);
analogWrite (PWMPin2, 0);
If your schematic looks like what i imagine, then you need to drive both sides of the H-bridge. You have 2 choices, either drive the high side with PWM and simply analogWrite a zero to the opposite phase, or else you can drive the phases equal and opposite, something like:
The second way is more typical for a servo to work, but am just getting my first Arduino so dont know how well that code would work here, it depends on if the two pins are phase coherent, ie running on the same timer of ATmega.
The simpler option to analogWrite (PWMPinX, 0); to the opposite side is pretty safe.
int value1;
int value2;
int pinread;
pinread == analogRead(potpin1);
if (pinread < 482)
value1 = map(pinread, 0, 481, 255, 0);
else if (pinread > 554)
value2 = map(pinread, 555, 1023, 0, 255);
I have tested the sketch and it works fine. I had to use outputs 2 and 3, 1 is not a PWM output.
When I try to open 2 transistors using one output it doesn't work???
When I use one transistor I can it works and I have checked direction using leds.
Could there be a timing problem? I checked the transistors and they work fine until I make the base common and it will not work anymore. Even when it's working with one transistor and I only connect the base of the second transistor (so not using collector and emiter) it doesn't work anymore.
EDIT: base only works but collector of second transistor connected makes it go bad.
I knew there was magic smoke involved in electronics but apperently there is even more magic???
