Code for reading values from HEDS-9100
I am using an rotary encoder HEDS-9100. I am unable to code to get incremental values on the serial monitor. If any one could help???
download
Please post your code and people can take a look and help
I literally need help to build a code if anyone could help..
Basically i am doing a project in which i am upgrading a digital inverted pendulum system and interfacing it with arduino...
If only we had some details...
downloads
this is encoder the kind of datasheet given in the topic..
Still waiting for your code... Things won't magically appear on the Serial monitor.
// Global Variables.
byte Values;
byte prev_state = 1; // to deduce rotational direction.
long index = 0;
boolean Clockwise = true; // currently not used.
int print_time = 100; // time between prints to the screen in [ms].
unsigned long past_time;
long prev_index = 0;
long curr_index = 0;
int displacement;
//To output the (int)displacement to the serial line byte by byte.
byte MSB;
byte LSB;
Serial.begin(57600);
Serial.flush();
Serial.print("\r I'm ready for action! \r");
delay(100);
// do nothing until we enter State_1 (Pins 2 and 3 both low). Naturally, there's a better way to enter the FSM in any state by reading the ports, but this will do for now.
// Then attach default interrupts.
while( (Values = PIND & B00001100) != B00000000 );
attachInterrupt(0,State_2 , RISING);
attachInterrupt(1,State_4 , RISING);
past_time = millis();
void State_1()
switch (prev_state)
case 2:
index++;
// Clockwise = true;
prev_state = 1;
case 4:
index--;
// Clockwise = false;
prev_state = 1;
default:
Serial.println("Error");
// should never happen unless we skip indices.
// detach the existing interrupts and reassign new conditions.
detachInterrupt(0); detachInterrupt(1);
attachInterrupt(0, State_2, RISING);
attachInterrupt(1, State_4, RISING);
void State_2()
switch( prev_state)
case 1:
index++;
prev_state = 2;
case 3:
index--;
prev_state = 2;
default:
attachInterrupt(0, State_1, FALLING);
attachInterrupt(1, State_3, RISING);
void State_3()
switch (prev_state)
case 2:
index++;
prev_state = 3;
case 4:
index--;
prev_state = 3;
default:
attachInterrupt(0, State_4, FALLING);
attachInterrupt(1, State_2, FALLING);
void State_4()
switch (prev_state)
case 3:
index++;
prev_state = 4;
case 1:
index--;
prev_state = 4;
default:
attachInterrupt(0, State_3, RISING);
attachInterrupt(1, State_1, FALLING);
// Prints the index at the specified interval.
if (millis() >= (past_time + print_time) )
// we can't say "==" because the loop might not fall on that precise moment.
// print current displacement
displacement = (int)index;
// Two output options: binary and ascii
// Here's ASCII
Serial.println(displacement);
It looks like you are making this way harder than necessary. Your routines that react to the interrupts should be very, very short and just move to a different state. You do not need to dettach and re-attach those interrupts every time. Just have 1 routine that looks at the pins and figures out what state you are in....
OR.... Just download the encoder.h library which basically does that. Try the examples, look at the code.
