Code for RFID and servo
Hi all! I have a project in which I'm using a RFID reader to read a tag and subsequently, move a servo when the right tag is read. I was able to successfully have the servo move, but it doesn't sweep it's entire 180 degree limits. It only moves something like 10 degrees. I've done the sweep tutorial and tried different methods, but somehow they don't work. I also tried using the servo library, but it doesn't seem to move the servo at all when the code is uploaded.
This is my first time doing programming for devices, so a lot of the advanced stuff is beyond my reach (that and I'm a mech E, so I'm really lost when it comes to this stuff =).
Here's my code:
// Modified by R. Moreno
#include <SoftwareSerial.h>
int val = 0;
char code[10];
int bytesread = 0;
int validate = 0; // Create a variable to store value when a tag is read
// Recognized tags = 1, unrecognized tags = 2
/** Adjust these values for your servo and setup, if necessary **/
int servoPin = 4; // control pin for servo motor
int minPulse = 500; // minimum servo position
int maxPulse = 2500; // maximum servo position
int turnRate = 100; // servo turn rate increment (larger value, faster rate)
int refreshTime = 20; // time (ms) between pulses (50Hz)
/** The Arduino will calculate these values for you **/
int centerServo; // center servo position
int pulseWidth; // servo pulse width
long lastPulse = 0; // recorded time (ms) of the last pulse
int ledPin = 13; //Sets pin 13 to LED
#define rxPin 8
#define txPin 9
// RFID reader SOUT pin connected to Serial RX pin at 2400bps to pin8
Serial.begin(9600); // Hardware serial for Monitor 9600bps
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW); // Activate the RFID reader
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
centerServo = maxPulse - ((maxPulse - minPulse)/2);
pulseWidth = minPulse; // Give the servo a starting point (or it floats)
// Original value of "centerServo"
pinMode(ledPin, OUTPUT); //Sets the digital pin as output
Serial.println(" Arduino RFID Door Unlocker");
scan(); //Scan tags
if (validate == 1) //if tag is recognized
open(); //Do function "open" (see below)
delay (500);
if (validate == 2) //if tag is not recognized
blink(); //Do function "blink" (see below)
delay (500);
void scan()
SoftwareSerial RFID = SoftwareSerial(rxPin,txPin);
RFID.begin(2400);
validate = 0; //Reset validate variable
if((val = RFID.read()) == 10)
{ // check for header
bytesread = 0;
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if( strncmp(code,"1D009F07D1", 10) == 0)
// if 10 digit code equals "1D009F07D1"
Serial.print("TAG code is valid "); // possibly a good TAG
Serial.println(code); // print the TAG code
validate = 1; //Sets "validate" to 1, accepting tag
else if( strncmp(code,"1D009FB1E6", 10) == 0)
// if 10 digit code equals "1D009FB1E6"
else if( strncmp(code,"12002EF4CC", 10) == 0)
// if 10 digit code equals "12002EF4CC"
Serial.print("TAG code is not valid: "); // possibly a bad TAG
validate = 2; //Sets "validate" to 2, denying tag
bytesread = 0;
delay(500); // wait for a second
void open()
pulseWidth = maxPulse;
// pulse the servo every 20 ms (refreshTime) with current pulseWidth
// this will hold the servo's position if unchanged, or move it if changed
if (millis() - lastPulse >= refreshTime)
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulseWidth); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
lastPulse = millis(); // save the time of the last pulse
delay(5000);
void blink()
digitalWrite(ledPin, HIGH); // sets the LED on
delay(2000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
delay(500); // waits for a 5 msec
Thanks to anyone who can help me out!
It will probably be easer to figure out what is wrong if you stick with the sweep or knob example sketches until you can get the servo to move. First thing is to check your power source. Some servos can draw more power when they start moving than the board can provide. Try using an external power source for the servo (remember that the grounds must be connected together).
Aye, actually that was typed wrong. I actually got the servo to sweep the full 180. I copied the code straight from that example into my code. But again, the servo somehow limits itself and only sweeps 10 degrees instead of the 180.
try changing your open function to something like this:
void positionServo( int pin, int pulseWidth, int duration)
   for(int i=0; i < duration/20; i++){
    digitalWrite(pin, HIGH);   // start the pulse
    digitalWrite(pin, LOW);    // stop the pulse
    delay(20);
void open()
  positionServo(servoPin,maxPulse,5000); // servo gets maxPulse for 5 seconds
  positionServo(servoPin,minPulse,1000); // servo gets minPulse for 1 second
