Code for RFID reader
I am trying to get a led to turn on when I put the correct RFID tag next to the reader. I am having problems with my if statement when it should be true it is coming as false. If anyone can help it would be great.
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
int  val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW);                  // Activate the RFID reader
pinMode(9, OUTPUT);
  digitalWrite(9, LOW);
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
        if(code == "06009GAE4"){           //This is the part with the problems
          Serial.println("Okay");
          digitalWrite(9, HIGH);
      bytesread = 0;
      digitalWrite(2, HIGH);                  // deactivate the RFID reader for a moment so it will not flood
           delay(1500);                       // wait for a bit
// extra stuff
// digitalWrite(2, HIGH);             // deactivate RFID reader
Thanks :slight_smile:
You can't use == to compare a character array to a string constant. Try:
        if(strcmp(code,"06009GAE4") == 0) {           //This is the part with the problems
It worked! Thank you very much. 8)
