Hi there,
I'm writing code for a pair of glasses that use an ultrasonic sensor to beep if an object is nearby in a particular range. In the glasses, the range can be set with a rotary encoder.
Here's the problem: the rotary encoder values are increasing even when I turn it the other way. I checked, and the rotary encoder is not the problem because I tried with the code provided on the general electronics website and the encoder works as it should. It's only not working with this code of mine. I even checked by isolating the function I wrote to handle the encoder (getRotValues) and that function is not the problem as in a new code base it works just fine. I would appreciate any help.
Here is the code:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 12
Adafruit_SSD1306 display(OLED_RESET);
// battery indicator definition
#define battery A3
//Ultrasonic sensor definition
#define trig 11
#define echo 10
//buzzer difinition
#define Buzz 4
//colour definitions
#define red 6
#define blue 7
#define green 8
//Encoder definitions
#define CLK 3
#define DT 2
#define mute 5
//A4 and A5 are SDA and SCL
float dist=0;
int Time=0;
int maxDist=275; // in Centimeters
int counter=0;
int cCLK;
int pCLK;
int potLim=0;
int potVal=0;
int buzzVal;
bool isMute;
pinMode(trig,OUTPUT);
pinMode(echo,INPUT);
pinMode(Buzz,OUTPUT);
pinMode(CLK,INPUT);
pinMode(DT,INPUT);
pinMode(mute,INPUT);
pinMode(red,OUTPUT);
pinMode(blue,OUTPUT);
pinMode(green,OUTPUT);
pinMode(battery,INPUT);
pCLK=digitalRead(CLK);
Wire.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextSize(0.5);
display.setTextColor(WHITE);
SendRecieve();
Intro();
void batteryCheck() {
int censorValue=analogRead(battery);
float voltage=censorValue * (4.2/1023.0);
float limit=4.2-2.4;
float percentage=((4.2-limit)/2.4)*100;
if((100-percentage)>=75) {
digitalWrite(red,1);
digitalWrite(blue,1);
digitalWrite(green,0);
else if((100-percentage)>=50) {
digitalWrite(blue,0);
digitalWrite(green,1);
else if((100-percentage)>=25) {
digitalWrite(red,0);
else {
void Intro(){
display.setTextSize(1);
display.setCursor(15,12);
display.print("LGBTQ+ CHASHME!!");
display.display();
delay(2000);
display.setTextSize(2);
display.setCursor(0,0);
display.print("By");
display.setCursor(0,16);
display.print("PhoenoPav");
display.display();
delay(2000);
for (int i=0; i<100; i++) {
digitalWrite(Buzz,1);
delay(10);
digitalWrite(Buzz,0);
void SendRecieve(){
digitalWrite(trig,0);
delay(3);
digitalWrite(trig,1);
delay(3);
Time=pulseIn(echo,HIGH);
dist=(Time*0.0344)/2;// for cm
//if (dist<0) {
//dist*=-1;
Serial.print("Distance: "); Serial.print(dist); Serial.print(" ");
void Beep(){
buzzVal=map(dist,0,maxDist,0,100);
for(int i=0;i<10;i++){
delay(buzzVal);
delay(buzzVal);
void getRotValues() {
cCLK=digitalRead(CLK);
if(pCLK!=cCLK) {
if(digitalRead(DT)!=cCLK) {
counter--;
if(counter<=0) {
counter=0;
else {
counter++;
if(counter>=maxDist) {
counter=maxDist;
potLim=counter;
pCLK=cCLK;
void Print(){
display.print("Max Distance: "); display.print(maxDist);
display.setCursor(0,10);
if(dist>maxDist) {
display.print(" Out of bounds");
else {
display.print("Distance: "); display.print(dist);
display.setCursor(0,20);
display.print("Limit: "); display.print(potLim);
display.display();
void toggleMute() {
if(digitalRead(mute) == 1) {
isMute=!isMute;
batteryCheck();
toggleMute();
getRotValues();
Print();
display.print("Max Distance: "); display.println (maxDist);
if((dist<potLim)&&(!mute)) {
Beep();
