Code for Sound Sensor & Vu Meter
Hello - I am still new to this forum so not sure if this post belongs here or under Sensors but here goes… I have designed an LED coffee table using an Arduino Mega which works great and I recently purchased this sound sensor and connected it to my Arduino Mega board.
The table includes a code for a Vu Meter which I was hoping to use the sound input from this unit for input but since I’m such a noob at coding C++, I have no idea how to alter the code to allow this unit to run the Vu Meter. Can anyone let me know using the code below how I can change the code to get Digital (or Analog) input from this Sound Sensor to feed values into the Vu Meter? The Sound Sensor is connected as follows:
VCC > 5v Power on Arduino
Ground > Arduino Ground
Out > Digital Pin 45 Arduino
/* LedTable
 * Written by: Ing. David Hrbaty
 * VU Meter animation based on FFT
#include <fix_fft.h>
#include <HSBColor.h>
#define BAR_HUE_DIFF 8
boolean vuRunning;
int curHue = 0;
// FFT data storage
char im[FIELD_WIDTH * 2], data[FIELD_HEIGHT * 2];
int prev[FIELD_HEIGHT];
// HSB/RGB data buffer
int rColor[3];
// Converts a 2d visualizer point to it's location on the strip
int getStripLocation(int col, int row)
  // The strips are in alternating directions. This adjusts the result for that.
  if (col % 2 == 0)
    row = FIELD_HEIGHT - row - 1;
  return col * FIELD_HEIGHT - row;
void initVUmeter() {
  vuRunning = true;
  analogReference(DEFAULT);
void runVUmeter()
  initVUmeter();
  int i, j, k;
  uint32_t color;
  int shift;
  int fft_start;
  int fft_count;
  int curData;
  int brightness;
  unsigned long prevUpdateTime = 0;
  unsigned long curTime = 0;
  while(vuRunning) {
  // Read analog input
  for (i = 0; i < FIELD_WIDTH * 2; i++)
    int val = (analogRead(3) + analogRead(2)) / 2;
    data[i] = val * 2;
    im[i] = 0;
    delay(2);
  // Perform FFT on data
  // HACK 4 represents 2^4, or 16 (FIELD_WIDTH * 2). Change this to adjust with FIELD_WIDTH!
  shift = fix_fft(data, im, 2, 0);
  // Clear pixels
  for (i = 0; i < FIELD_WIDTH * FIELD_HEIGHT; i++)
    setPixel(i, 0);
  // Set the proper pixels in each bar
  //for (i = 0; i < FIELD_WIDTH; i++)
  for (i = 9; i >=0; i--)
    // Each LED bar has 2 FFT frequencies that are summed together
    fft_start = i * 2;
    fft_count = 1;
    // Get a positive data point from the FFT
    curData = 0;
    for (k = 0; k < fft_count; k++)
      curData += sqrt(data[fft_start + k] * data[fft_start + k] + im[fft_start + k] * im[fft_start + k]);
    // Account for the ShiftyVU's filtering
    if (i == 0 || i == 9)
      curData /= 2;
    // Smoothly drop from peaks by only allowing data points to be one LED lower than the previous iteration.
    // This prevents seizure-inducing flashes which might be caused by the ShiftyVU's filtering (?)
    if (prev[i] > FIELD_HEIGHT && curData < prev[i] - FIELD_HEIGHT)
      curData = prev[i] - FIELD_HEIGHT;
    // Base color for each bar
    H2R_HSBtoRGB((curHue + i * 8) % 360, 99, 99, rColor);
    color = ((rColor[0]/2)<<16) + ((rColor[1]/2)<<8) + (rColor[2]/2);
    // If only the first LED is lit, but not fully. This is outside the for loop because the subtraction of
    // BAR_LENGTH causes the value to wrap around to a very high number.
    if (curData < FIELD_HEIGHT)
      brightness = curData * 99 / FIELD_HEIGHT;
      H2R_HSBtoRGB((curHue + i * BAR_HUE_DIFF) % 360, 99, brightness, rColor);
      //setPixel(getStripLocation(i, 0),color);
      //setTablePixel(0, i, color);
     // setTablePixel(i, 9, color);
     setTablePixelRGB(i, 9, rColor[0]/2,rColor[1]/2,rColor[2]/2);
     for (j = 0; j < FIELD_HEIGHT; j++)
     //for (j = 9; j >= 0; j--)
        // Light up each fully lit LED the same way.
        if (curData - FIELD_HEIGHT > (FIELD_HEIGHT-j) * FIELD_HEIGHT)
          //setPixel(getStripLocation(i, j),color);
          //setTablePixel(i, j, color);
           setTablePixelRGB(i, j, rColor[0]/2,rColor[1]/2,rColor[2]/2);
        else if (curData > (FIELD_HEIGHT-j) * FIELD_HEIGHT)
          // Dims the last LED in the bar based on how close the data point is to the next LED.
          brightness = (j * FIELD_HEIGHT - curData) * 99 / FIELD_HEIGHT;
          H2R_HSBtoRGB((curHue + i * BAR_HUE_DIFF) % 360, 99, 255, rColor);
          color = ((rColor[2]/2)<<16) + ((rColor[0]/2)<<8) + (rColor[1]/2);
          setTablePixelRGB(i, j, rColor[2]/2,rColor[0]/2,rColor[1]/2);
    // Store all of the data points for filtering of the next iteration.
    prev[i] = curData;
  // Cycle through all the colors.
  if (curHue == 359)
    curHue = 0;
    curHue++;
  // Display the strip.
  showPixels();
  do{
      readInput();
      if (curControl == BTN_EXIT){
        vuRunning = false;
      curTime = millis();
      delay(5);
    while ((curTime - prevUpdateTime) <20);//Once enough time  has passed, proceed. The lower this number, the faster the game is
    prevUpdateTime = curTime;
Why? The device is an analog device.
Did you notice that most people bought an OpAmp board to use with that device? Did you wonder why?
PaulS:
I thought this was analog but I saw this tutorial and connected according to this. I can switch to Analog though. As I said, I am new to this so no I was not aware people were using OpAmp boards nor did I wonder why. Do you have a link to a post with an explanation of which OpAmp 'board' people are using and how they've implemented it? Would it be something like this? SparkFun OpAmp Breakout - LMV358 - BOB-09816 - SparkFun Electronics
Have you tried Googling "driving a vu meter" Shows a lot of links
ZOR2:
yeah I have been googling "arduino vu meters" and "coding vu meter arduino" for a while. I guess I can go back to that, just hoping someone on here had some information other than blindly googling it. I'm still working that angle but alot of solutions in 'driving a vu meter' don't really apply to the Arduino or code.
Your link, https://www.amazon.com/gp/product/B00AF2GB1U/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1, showed what people usually buy with the microphone board. Since one of the devices that is usually bought with it is an OpAmp board, I'm assuming that one is needed. Since the board you have contains a microphone, and microphones are analog devices, I'm assuming that connecting it to a digital pin is a waste of effort.
I could be wrong, though. I was once.
