I have an avoidance robot with the ping sensors (not at that point yet)
I have assembled and coded the servo motor on the ping sensors.(works well)
Now I would like to make the two motors move!!
I am using an H board and breadboard I have an Arduino uno I am very new to this
Please be gentle
Stang
What is your question? It is difficult to help you when we do not know what you need help with.
Try read some of these pages: Arduino Playground - InterfacingWithHardware.
Hi sorry bout the confusion
I have an Arduino uno..Ive never used them before. I have got an H bridge,which I used to success on Raspi pi. but prefer the uno.
I wanted to simply move a dc motor, 2 wires,
I can get it to run non stop, presume the program is not picking up the pin I have attached, because it doesn't delay or
stop on high or low..I use a basic breadboard.
Could you please advise me
I need it simple.
Stan
You should either describe exactly how everything is connected or draw a diagram and/or take a picture.
just one motor will do!!!!
Hi in response to last reply asking me to be clear on problem.
I connect one lead from motor to pin number 9 on breadboad
I connect on e lead from arduino pin 9 to pin 9 on breadboard above lead from motor
I connect second lead from motor to pin 11 on breadboad
I connect one lead from arduino pin 11 to pin 11 on breadboard above lead from motor
I connect lead from negative pin on arduino to negative strip on breadboard
I connect lead from 5.5v positive pinon arduino to positive strip on breadboard
I connect lead from negative strip on breadboard to pin 11 o breadboard below lead from motor
I connect leads from positive strip to pin 9 on breadboard above lead from arduino.
int leftMotor1 = 9;
int leftMotor2 = 11;
int leftPin1=leftMotor1;
int leftPin2=leftMotor2;
pinMode(leftPin1=9, OUTPUT);
pinMode(leftPin2=11, OUTPUT);
digitalWrite(leftPin1, HIGH);
digitalWrite(leftPin2, LOW);
digitalWrite(leftMotor1, LOW);
digitalWrite(leftMotor2, LOW);
the motor just runs its seems as if it is not receiving commands from the pins
Please help
Im such a newbie
Stan
