Code for Wemos D1 mini won't compile
Three years ago I made a device that uses a mini D1 R2, an RTC, an SD card, and U8G2 graphics. It was working. Two days ago I installed esp8266, ver.3.0.2. Noe I get compiler errors. Thinking it might have to do with the SD card or graphics, I wrote a very simple sketch that just reads the RTC and prints the result to the serial monitor. I get the same errors. I tried other versions of wemos cards with same result.
Non verbose (down load) error file is listed below. I don't know what it tells me, so any help would be greatly appreciated.
Arduino: 1.8.9 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Traceback (most recent call last):
File "C:\Users\Richard\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py", line 211, in
sys.exit(main())
File "C:\Users\Richard\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py", line 192, in main
to_addr=4096
File "C:\Users\Richard\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py", line 187, in wrapper
write_bin(out=out, args=args, **kwargs)
File "C:\Users\Richard\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py", line 75, in write_bin
[size, addr] = get_segment_size_addr(elf, segment, args.path)
File "C:\Users\Richard\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py", line 47, in get_segment_size_addr
p = subprocess.Popen([path + '/xtensa-lx106-elf-objdump', '-h', '-j', segment,  elf], stdout=subprocess.PIPE, universal_newlines=True )
File "D:\obj\Windows-Release\37win32_Release\msi_python\zip_win32\subprocess.py", line 775, in init
File "D:\obj\Windows-Release\37win32_Release\msi_python\zip_win32\subprocess.py", line 1178, in _execute_child
FileNotFoundError: [WinError 2] The system cannot find the file specified
exit status 1
Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
option enabled in File -> Preferences.
Simple WeMos sketch that generates above error mesages.
// Uses WeMos D1 mini on COM8
#include <Wire.h>
#include <RTClib.h>
RTC_DS3231 rtc;
int oldMinute;
int oldHour;
int oldDay;
int oldMonth;
int nowHour;
int nowMinute;
int nowDay;
int nowMonth;
int nowSecond;
int I;
void setup() // ****************start of setup *****************
while (!Serial) {
// wait for serial port to connect.
if (! rtc.begin())
Serial.println("Couldn't find RTC");
while (1);
// This line sets the RTC with an explicit date & time, for example to set
// April 31, 2019 at 10:10 am you would call:
// (year, month, day-of-month, hour, minute, second)
rtc.adjust(DateTime(2021, 11, 1, 10, 5, 0));
DateTime now = rtc.now();
// set initial hour
oldMinute = now.minute();
oldHour = now.hour();
oldDay = now.day();
oldMonth = now.month();
Serial.print("initial value of month, day, and hour = ");
Serial.print(oldMonth);
Serial.print(", ");
Serial.print(oldDay);
Serial.print(", ");
Serial.print(oldHour);
Serial.print(", ");
Serial.println(oldMinute);
} //*************** end of setup()********************
void loop() // **START OF LOOP
  nowHour = now.hour();
  nowMinute = now.minute();
  nowDay = now.day();
  nowMonth = now.month();
  nowSecond = now.second();
  if(nowMinute != oldMinute)
  Serial.print("current month, day, hour, minute and second: ");
  Serial.print(nowMonth);
  Serial.print("  ");
  Serial.print(nowDay);
  Serial.print("  ");
  Serial.print(nowHour);
  Serial.print("  ");
  Serial.print(nowMinute);
   Serial.print("  ");
  Serial.println(nowSecond);
 oldMinute = nowMinute;
} //END OF LOOP**
Please post that sketch
what is "D:\obj\Windows-Release?
please RE-edit your first posting with the sketch by using this method:
click on the pencil-icon below your first posting to activate edit-mode.
mark all the code and delete it
Then You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
the code doesn't matter. the toolchain is broken
Is there a way I can fix it?
Thanks
setting up a complete new installation of the arduino-IDE actual version 1.8.16
and re-install all additional libraries
second version:
unzipping a portable installation of the Arduino-IDE
and copying your folder "library" from your original installation into the subfolder "portable\sketchbook"
and adding the additional board-url.
best regards Stefan
I asked
It's having problems in a Python (.py) program in the Arduino esp8266 3.0.2 installation. If reinstalling the ESP8266 support doesn't help, I would try reinstalling Python.
John:
That’s what I figured when I looked at the error log. The previous version of ESP8266 I was using (Jan 2019 according to the dates on some sketches) worked just fine. I tried reinstalling ESP8266 to an earlier version. But I seemed to get ver. 3.0.2 again. I’ll try that approach again, and reinstall Python..
Thanks for your suggestion.
R
