Code form Uno don't work on Mega 2560
Hello
I need help. I want to make this
but i want to do it on arduino mega, beacuse i want to add few more temp sensors and other stuff.
I can upload sketch witchout problem but then nothings happend, only black screen.
i think that it can be problem with PinChangeInterrupt librrery, that only my suspiciousys.
Sorry for my bad English.
Bi-TripCo_Metric_Celcius.ino (43.2 KB)
I would try to help but I can't run the IDE on my device and am reluctant to download code. If you post your code as described in the how to use this forum-please read stickies, everyone can see the code and, perhaps, offer assistance.
Not all pins on the Mega support pin change interrupts. The SoftwareSerial reference page has a list of pins that do support pin change interrupts. You need to use a pin that does.
the guy who wrote the code needed that library because the UNO has 2 hardware interrupt pins. the Mega has 21.
Pinchange Interrupt Pins:
Digital Pin 0,22,23,24,25,10,11,12,13,15,14
Analog Pin 6,7,8,9,10,11,12,13,14,15
This pin is used for pin change interrupt. Enable bit of pinchange interrupt must be set with global interrupt enable.
Application :
Rotary encoder, push button based interrupt and others.
Example :
pinMode(0, OUTPUT);
pinMode(1, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(1), LOW, CHANGE);
from Arduino Mega Tutorial
remove that PinChangeInterrupt library and use hardware interrupts
You need to read that a bit closer, I think.
There are FIVE external interrupts. The highest pin number with an external interrupt is 21.
External Interrupts: 2 (interrupt 0), 3 (interrupt 1), 18 (interrupt 5), 19 (interrupt 4), 20 (interrupt 3), and 21 (interrupt 2). These pins can be configured to trigger an interrupt on a low level, a rising or falling edge, or a change in level. See the attachInterrupt() function for details.
I can't poste a code beacouse it has more than 9000 characters
Removing Pin Change Interrupt library from code seems too difficult for me right now, maybe there is simpler way?
