code from arduino Uno and porting over to mega
Hi
I am working on a project to and my uno ran out of resources so I moved to a mega 2560.
I did not know the pins and everything is different.
my code was working on the uno but now it is not doing anything that I can tell on the mega.
I downloads but I get no output
I have an " Adafruit Ultimate GPS","Adafruit BMP085", and an SD card to write to.
my code is shown below.
can I get some help?
also, there are all types of tutorials on the uno. can I get a good tutorial on the Arduino mega 2560 so I don't have to bother you when I add my servo and rangefinder
//include for SD card
#include <SD.h> //Load SD card library
#include<SPI.h> //Load SPI Library
// arduino uno pin 13(SCK),12(MISO),11(MOSI)
//arduno mega pin SPI: 50 (MISO), 51 (MOSI), 52 (SCK),
//include for Adafruit_BMP085
#include <Wire.h>
#include <Adafruit_BMP085.h>//Load BMP085 Library
//#include <Adafruit_GPS.h> //Install the adafruit GPS library
// see parse example for more objects to read
#include <Adafruit_GPS.h> //Load gps Library
#include <SoftwareSerial.h> //Load the Software Serial library
//SoftwareSerial mySerial(3, 2); Uno code
SoftwareSerial mySerial(18,19); //Initialize the Software Serial port using Serial 1: 19 (RX) and 18 (TX);
//Object setup
Adafruit_GPS GPS(&mySerial); //Create the GPS Object
File mySensorData; //Data object you will write your sesnor data to
Adafruit_BMP085 bmp; //Create the Temp/Pres Object
// Variables setup
float tempC; // Variable for holding temp in C
float tempF; // Variable for holding temp in F
float pressure; //Variable for holding pressure reading
float altitude; //Variable for holding altitude
String NMEA1; //Variable for first NMEA sentence
String NMEA2; //Variable for second NMEA sentence
char c; //to read characters coming from the GPS
int chipSelect = 4; //chipSelect pin for the SD card Reader
boolean test = true ; // true or false; used for SD test print
boolean test1 = true ; // true or false; used for NMEA test print
float mpsConvertion = 1.15077945; //used to convert from knots to MPS 1 knot = 1.15077945 mph
float MPS =0.0; //sets mph
if (!bmp.begin()) {//checks for BMP085 is responding
Serial.println("Could not find a valid BMP085 sensor, check wiring!");
while (1) {}
}else{
Serial.println("valid BMP085 sensor!");
Serial.begin(115200); //Turn on serial monitor
GPS.begin(9600); //Turn on GPS at 9600 baud
GPS.sendCommand("$PGCMD,33,0*6D"); //Turn off antenna update nuisance data
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA); //Request RMC and GGA Sentences only
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); //Set update rate to 1 hz
pinMode(10, OUTPUT); //Must declare 10 an output and reserve it to keep SD card happy
SD.begin(chipSelect); //Initialize the SD card reader
if (SD.exists("NMEA.txt")) { //Delete old data files to start fresh
SD.remove("NMEA.txt");
if (SD.exists("GPSData.txt")) { //Delete old data files to start fresh
SD.remove("GPSData.txt");
getTEMP();
readGPS();
if(GPS.fix==1) { //Only save data if we have a fix
mySensorData = SD.open("NMEA.txt", FILE_WRITE); //Open file on SD card for writing
mySensorData.println(NMEA1); //Write first NMEA to SD card
mySensorData.println(NMEA2); //Write Second NMEA to SD card
mySensorData.close(); //Close the file NMEA.txt
mySensorData = SD.open("GPSData.txt", FILE_WRITE);
mySensorData.print(GPS.latitude,4); //Write measured latitude to file
mySensorData.print(GPS.lat); //Which hemisphere N or S
mySensorData.print(",");
mySensorData.print(GPS.longitude,4); //Write measured longitude to file
mySensorData.print(GPS.lon); //Which Hemisphere E or W
mySensorData.print(GPS.altitude);
mySensorData.print(MPS);
mySensorData.println(",");
mySensorData.print(bmp.readTemperature());
mySensorData.print("C");
mySensorData.print(pressure);
mySensorData.println("Pa.");
mySensorData.println("");
mySensorData.close(); //Close the file GPSData.txt
if(test){ //if test is set to true then test code will print to monitor
//Serial.print("Pressure = ");
//Serial.print(bmp.readPressure());
//Serial.print(" Pa");
Serial.print("Temperature = ");
Serial.print(bmp.readTemperature());
Serial.println("C");
Serial.print(GPS.latitude,4); //Write measured latitude to file
Serial.print(GPS.lat); //Which hemisphere N or S
Serial.print(",");
Serial.print(GPS.longitude,4); //Write measured longitude to file
Serial.print(GPS.lon); //Which Hemisphere E or W
Serial.print(",");
Serial.print(GPS.altitude);
//Serial.print(",");
//Serial.print(GPS.speed); //displays speed in knots
Serial.print(",");
Serial.print(MPS); //displays speed in Miles per-hour
Serial.print(",");
//Serial.print(tempC, 1);
Serial.print("C");
} else{ //if test
Serial.println("Not in test mode. will not display print lines");
} //if(GPS.fix==1)
//delay(500);
void readGPS() {
clearGPS();
while(!GPS.newNMEAreceived()) { //Loop until you have a good NMEA sentence
c=GPS.read();
GPS.parse(GPS.lastNMEA()); //Parse that last good NMEA sentence
NMEA1=GPS.lastNMEA();
c=GPS.read();
NMEA2=GPS.lastNMEA();
//Serial.println(NMEA1);
//Serial.println(NMEA2);
//Serial.println("");
void clearGPS() { //Clear old and corrupt data from serial port
c=GPS.read();
c=GPS.read();
c=GPS.read();
void getTEMP() {// Read Temperature
tempC = bmp.readTemperature(); //read temp in C
tempF = (tempC * 1.8 ) + 32.0; //convert temp in C to f
tempF = (tempC * 1.8) + 32.0;
Code tags, please.
I added a space so the editor didn't take my code as an emoji.
that's all my code it worked on the Arduino Uno, now trying to port to the mega 2560
That's not how it works here. Use code tags.
you asking for "Use code tags."
Not sure what you are asking for,
I don't need help with the code. I need help with the setup of the pins so my cod can read from the sensors
Read how to post your fish, sorry code, into this forum .
It’s in the how to use this forum section.
fredguthrie:
Yes you do. Read the "how to use the forum" readmes. You might also read the Mega Datasheets, it always helps to know what you have in your hand, and all is explained therein.
Mega has four hardware serial ports. Your main problem is that you are using software serial on a hardware serial port. Code problem.
You might consider the sense in using software serial at all on a Mega. Code problem.
If you really needed to call pin 10 as output in the SD section for Uno, you need to call pin 53 on a Mega. Code problem.
thanks, MorganS, and Hammy I found what I needed
I added 2 lines to better define the inputs/output.
Adafruit_GPS GPS(&Serial3); //Create the GPS Object
const int chipSelect = 53; //chipSelect pin for the SD card Reader
//SD card for arduno mega pin SPI: 50-(MISO), 51-(MOSI), 52-(SCK),ss/cs-53
//Adafruit_BMP085 SCL ->pin21,SDA ->pin20
now my code works.
now I can add 2 servos a lidar and GPRS that's why I had to move from the UNO to the mega
fred, take the posting hints as guidance, not insults.
We like to help if you try your hardest to help yourself!
