Arduino:1.8.15 (Windows 10), Kart:"Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Mehmet\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558 -warnings=none -build-cache C:\Users\Mehmet\AppData\Local\Temp\arduino_cache_178461 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Mehmet\Desktop\Workspace\ISSD_Project\Coding\Voltage_Measurement_Relays_Control\Voltage_Measurement_Relays_Control.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Mehmet\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558 -warnings=none -build-cache C:\Users\Mehmet\AppData\Local\Temp\arduino_cache_178461 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Mehmet\Desktop\Workspace\ISSD_Project\Coding\Voltage_Measurement_Relays_Control\Voltage_Measurement_Relays_Control.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\sketch\Voltage_Measurement_Relays_Control.ino.cpp" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\sketch\Voltage_Measurement_Relays_Control.ino.cpp" -o "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\preproc\ctags_target_for_gcc_minus_e.cpp"
Çalışma derleniyor...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\sketch\Voltage_Measurement_Relays_Control.ino.cpp" -o "C:\Users\Mehmet\AppData\Local\Temp\arduino_build_284558\sketch\Voltage_Measurement_Relays_Control.ino.cpp.o"
C:\Users\Mehmet\Desktop\Workspace\ISSD_Project\Coding\Voltage_Measurement_Relays_Control\Voltage_Measurement_Relays_Control.ino: In function 'void setup()':
Voltage_Measurement_Relays_Control:53:5: error: a function-definition is not allowed here before '{' token
Voltage_Measurement_Relays_Control:59:5: error: 'else' without a previous 'if'
Voltage_Measurement_Relays_Control:63:47: error: expected primary-expression before '>' token
if (get_channel_voltage(INPUT_CHANNEL_2)) > ALARM_LEVEL_2)
Voltage_Measurement_Relays_Control:72:47: error: expected primary-expression before '<' token
if (get_channel_voltage(INPUT_CHANNEL_1)) < ALARM_LEVEL_3)
Voltage_Measurement_Relays_Control:82:3: error: expected '}' at end of input
exit status 1
