Code help for a Minecraft Noteblock using the Adafruit Neotrellis
Hello, I'm trying to re-create the minecraft noteblock in real life with a launchpad (adafruit neotrellis) and a laser cut noteblock. After I assembled the 2x2 matrix of neotrellis, I couldn't figure out why the example code wouldn't work from the seesaw library even when I replaced it with the code for the matrix and (attempted to replace) hex codes for identifying each board. Please help me figure out how to even make this thing light up!
Here is a link to the adafruit website about matrixing the neotrellis: Arduino Code | Adafruit NeoTrellis | Adafruit Learning System
Images: https://drive.google.com/drive/folders/1MuJ3_EC6OasX01I6P-4IPlW78owlPwn0?usp=sharing
Code:
#include "Adafruit_NeoTrellis.h"
#define Y_DIM 8 //number of rows of key
#define X_DIM 8 //number of columns of keys
//create a matrix of trellis panels
Adafruit_NeoTrellis t_array[Y_DIM/4][X_DIM/4] = {
  { Adafruit_NeoTrellis(0x2F), Adafruit_NeoTrellis(0x30) },
  { Adafruit_NeoTrellis(0x31), Adafruit_NeoTrellis(0x32) }
If you were using a 2x2 array of NeoTrellis boards, the above lines would be:
  { Adafruit_NeoTrellis(0x2E), Adafruit_NeoTrellis(0x2F) },
  { Adafruit_NeoTrellis(LOWER_LEFT_I2C_ADDR), Adafruit_NeoTrellis(LOWER_RIGHT_I2C_ADDR) }
//pass this matrix to the multitrellis object
Adafruit_MultiTrellis trellis((Adafruit_NeoTrellis *)t_array, Y_DIM/4, X_DIM/4);
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return seesaw_NeoPixel::Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return seesaw_NeoPixel::Color(255 - WheelPos * 3, 0, WheelPos * 3);
   WheelPos -= 170;
   return seesaw_NeoPixel::Color(0, WheelPos * 3, 255 - WheelPos * 3);
  return 0;
//define a callback for key presses
TrellisCallback blink(keyEvent evt){
  if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_RISING)
    trellis.setPixelColor(evt.bit.NUM, Wheel(map(evt.bit.NUM, 0, X_DIM*Y_DIM, 0, 255))); //on rising
  else if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_FALLING)
    trellis.setPixelColor(evt.bit.NUM, 0); //off falling
  trellis.show();
  return 0;
  //while(!Serial);
  if(!trellis.begin()){
    Serial.println("failed to begin trellis");
    while(1);
  /* the array can be addressed as x,y or with the key number */
  for(int i=0; i<Y_DIM*X_DIM; i++){
      trellis.setPixelColor(i, Wheel(map(i, 0, X_DIM*Y_DIM, 0, 255))); //addressed with keynum
      trellis.show();
      delay(50);
  for(int y=0; y<Y_DIM; y++){
    for(int x=0; x<X_DIM; x++){
      //activate rising and falling edges on all keys
      trellis.activateKey(x, y, SEESAW_KEYPAD_EDGE_RISING, true);
      trellis.activateKey(x, y, SEESAW_KEYPAD_EDGE_FALLING, true);
      trellis.registerCallback(x, y, blink);
      trellis.setPixelColor(x, y, 0x000000); //addressed with x,y
      trellis.show(); //show all LEDs
      delay(50);
  trellis.read();
  delay(20);
Thanks!
