Code help grouping id fingerprint scanner
I have problem coding to write between id, can anybody help me solve it?
I have fingerprint scanner project, I want to blink the led with 1pin output for 5 id.
If I write it manually until 15 id the scanner become slow to back to return.
I frustating coding with it
if(finger.fingerID==1) ==> its possible to id1 until id5?
digitalWrite(12, HIGH);
delay(3000);
digitalWrite(12, LOW);
this my code, very slow to return
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  Serial.println("Adafruit finger detect test");
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(10, OUTPUT);
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
  Serial.println("Waiting for valid finger...");
void loop()                     // run over and over again
  delay(50);            //don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  // found a match!
  delay(3000);
   if(finger.fingerID==2)
  delay(3000);
   if(finger.fingerID==3)
  delay(3000);
   if(finger.fingerID==4)
  delay(3000);
   if(finger.fingerID==5)
  delay(3000);
   if(finger.fingerID==6)
  digitalWrite(11, HIGH);
  delay(3000);
  digitalWrite(11, LOW);
   if(finger.fingerID==7)
  delay(3000);
   if(finger.fingerID==8)
  delay(3000);
   if(finger.fingerID==9)
  delay(3000);
   if(finger.fingerID==10)
  delay(3000);
   if(finger.fingerID==11)
  digitalWrite(10, HIGH);
  delay(3000);
  digitalWrite(10, LOW);
   if(finger.fingerID==12)
  delay(3000);
   if(finger.fingerID==13)
  delay(3000);
   if(finger.fingerID==14)
  delay(3000);
   if(finger.fingerID==15)
  delay(3000);
  return finger.fingerID;
Thanks
  delay(3000);
Your problem is that you have the braces in the wrong place. Written this way, only the first line in that block is conditional. The delay call and the call to write the pin LOW will happen whether the fingerID equals 4 or not. So you are getting a 3 second delay for every check regardless of whether it matched or not.
If statements should be written this way:
   if(finger.fingerID==4){
  delay(3000);
The code block starts after the if statement, not before.
And, incidentally, it is possible to do what you ask:
if(finger.fingerID >=1 && finger.fingerID <= 5)
This will be true for any value from 1 to 5 inclusive.
now its work perfectly, thanks to you Delta_G. GBU
Even more condensed (replacing all the if’s), you could write
  byte id = finger.fingerID; // for typing convenience
  if (id > 0 && id < 16) { // filters values to 1-15
    byte ledPin = 12 - ((id - 1) % 5); // maps 1-5 to 12, 6-10 to 11, 11-15 to 10
    digitalWrite(ledPin, HIGH);
    delay(3000);
    digitalWrite(ledPin, LOW);
