Hi I am trying to work with this code to learn more but cannot get it to compile and run on UNO R3 board. I have put AverageList into the Library folder but no worky.
#include <AverageList.h>
const byte LIST_SIZE = 20;
//enable user feedback
//this is used for storage, an array of ints
int arr[LIST_SIZE] = {0};
//initialize an AverageList object that operates on ints
AverageList<int> testList(arr, LIST_SIZE);
//take samples
for (int i = 0; i < LIST_SIZE; i++) {
testList = analogRead(2);
delay(20);
Serial.println( testList.getTotalAverage());
You need to have a loop() function, even if it is empty.
If you got the file from the Playground, it is a version written for an older IDE. You need to replace the #include<WProgram.h> with #include<Arduino.h> in the AverageList.h file in the libraries folder.
The indexer is missing for the array in the for loop. It should be:
testList[i] = analogRead(2);
In the future, please include the error messages in your post and/or describe the issue(s) that you have. Makes to easier for us to help.
//take samples
delay(20);
So read the analogue input 20 times overwriteing the testList variable every time, when the loop is finished find the avrage of an array that doesn’t exist.
Put each reading in a different place in your list you defined as arr and then find the avrage of that.
Mind you it is such a stupid library to use, why not just calculate the sum total as you read each sample and then divide that by the number of samples. Why use a library for that?
