Code help required
If possible, could someone help with the code (listed below) please? I cant get it to compile. Any help would be very much appreciated.
Kind regards,
Regiment1275
}// Code for Arduino Tachometer using IR Sensor
#include <LiquidCrystal.h>
LiquidCrystal lcd(3, 2, 4, 5, 6, 7);
#define sensor 18
#define start 10
int delay1()
//unsigned int long k;
int i, j;
unsigned int count = 0;
for (i = 0; i < 1000; i++)
for (j = 0; j < 1227; j++)
if (digitalRead(sensor))
count++;
while (digitalRead(sensor));
return count;
pinMode(sensor, INPUT);
pinMode(start, INPUT);
pinMode(13, OUTPUT);
lcd.begin(16, 2);
lcd.print("Techometer");
lcd.setCursor(0, 1);
lcd.print("Circuit Digest");
delay(2000);
digitalWrite(start, HIGH);
void loop( )
unsigned int time = 0, RPM = 0;
lcd.clear();
lcd.print(" Please Press ");
lcd.print("Button to Start ");
while (digitalRead(start));
lcd.clear();
lcd.print("Reading RPM.....");
time = delay1();
lcd.clear();
lcd.print("Please Wait.....");
RPM = (time * 12) / 3;
delay(2000);
lcd.clear();
lcd.print("RPM=");
lcd.print(RPM);
delay(5000);
You have a closing brace on the first line.
@regiment1275, can you please spend some time reading How to get the best out of this forum.
Next edit your post and add code tags to the code that you posted.
Hi Wildbill,
Thank you for your help. I also noticed that it shows void loop errors as well. Im using an Arduino Uno R3. I also need to monitor vibration levels from a SW2480 sensor and also display this. Can you help with this please?
What errors are you getting?
Hi Wildbill,
sketch_jun04c:6:1: error: expected declaration before '}' token
exit status 1
See reply #2...
Hi @regiment1275
See reply #2... and
Last line = };
unnecessary this " ; "
RV mineirin
You force the user to wait for nothing. You do calculations that are completed in milliseconds, then print "please wait" and do nothing at all for 2 seconds. Is that to make it seem like it's a difficult calculation?
The code was sent to me to use by a colleague
Doesn't that stand a very good chance of overflowing?
This colleague?
https://circuitdigest.com/microcontroller-projects/tachometer-using-arduino
Sure would be easier to follow if you had just told us about this.
I was sent the raw code by my colleague . No link was included to the original source
How's that working out?
It ‘s working now. I followed the advice given by yourself and others. Many thanks for all of your help.
